Clutch master stage 3 chatter, normal?
Old Jul 20, 2011 | 11:02 AM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Originally Posted by prodigymb
i have a new OEM flywheel, new CM Stage 3 with fiber tough, new pilot bearing, new throwout bearing, new pressure plate and I still get chatter
i havent looked into my tranny mount yet...hope thats it
Did u get it figured out?
Old Jul 20, 2011 | 11:24 AM
johnspeed's Avatar
Hi,I had the same thing with my CM stage 3 set-up,,,So,I took it out and went with the set-up below that ,without the fiber tough on the one side of the disc,,,,And now its less annoying/smoother and it holds my 540HP and 600TQ level, on a AWD Mustang Dyno......Good Luck
Old Jul 20, 2011 | 07:00 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
4k miles and still no chatter here
Old Jul 21, 2011 | 07:30 AM
as clutch broke in. chatter pretty much went away...
#TeamAIM
Old Jul 21, 2011 | 09:35 AM
REVS11's Avatar
As the master was going out the chatter was huge. Swapped the master and it got a lot better.
Could still be a little bit better, maybe improves over time. However it's a high hp clutch and pressure plate so might just have to drive around it.
Old Jul 21, 2011 | 07:28 PM
heavychevy's Avatar
I have to be perfect (or clutch dumping) in first gear to prevent chatter with the CM3. It's already hard enough not to stall. It's a finicky clutch in first, but it grips like crazy when you want it to.
Old Jan 8, 2014 | 07:51 AM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
I have clutch chatter with my CM stage 3 as well. It actually only started after break in. It is only when taking off from a stop or in reverse. The clutch holds perfectly though.
Feelgood MD
Mar 24, 2016 09:35 AM
shifter_
Sep 8, 2015 12:07 PM
yumaverick
Sep 2, 2015 03:48 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
