codes p0491 an p0492
Old Mar 2, 2011 | 06:49 AM
milk911's Avatar
milk911 is infamous around these parts
hi guys, i got this problems on my car. has anybody got this and got it fixed!? thanks
Old Mar 2, 2011 | 06:55 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Old Mar 2, 2011 | 07:52 AM
jpflip's Avatar
Related to your air pump. When you start the car can you hear this pump starting in the right forward corner of the engine bay ? This electric pump supply air to the catalytic converter at start for converter efficiency. If the pump start it is normally a leak in the small sense lines on top of the engine. But the bad part it is possible to be related to a faulty diverter valve.
Old Mar 2, 2011 | 09:26 AM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
I had the same issue I had a huge vacume leak. First check to see if the pump starts up then check the hoses, also your dv's. Good luck!
Old Mar 2, 2011 | 06:34 PM
milk911's Avatar
Thanks everyone I will see if I have an vacuum leak!! I'm glad I join this forum!!
milk911's Avatar
I keep this updated...
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
PelicanParts.com
997 Vendor Classifieds
Oct 5, 2015 01:07 PM
Oct 2, 2015 02:23 PM
nagual911
Oct 1, 2015 01:52 AM
