motorsports clutch pack for GT2 LSD
Old Mar 9, 2011 | 08:50 PM
Prche951's Avatar
Wondering, if anyone sells these or can install these for a GT2 LSD.
Old Mar 9, 2011 | 09:22 PM
Tim941NYC's Avatar
Yes. BMC & G, Gbox, and TRG to name a few. Will you be shipping the lsd or do you need the unit to be removed?
Old Mar 10, 2011 | 04:12 AM
Prche951's Avatar
No the unit is already out of the car, but will need to install it in place of the std open diff. This LSD is basically brand new out of a babied 500 mile GT2. So there is nothing wrong with it now.
Old Mar 10, 2011 | 08:29 AM
Basic's Avatar
Basic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant future
Is it going back into the same car?
Old Mar 10, 2011 | 09:34 AM
Prche951's Avatar
no, it's going in a different car.
Old Mar 10, 2011 | 06:20 PM
Tim941NYC's Avatar
I don't think you will need to re shim the lay shaft as its the same ring gear and pinion shaft, but I would check the backlash for proper contact. There are shims that locate the diff between the bearings they are cheap but the bearing on the ring gear side is a major PIA.. You will most likely wreck it trying to dial the shims in. Last time I honed out the old bearing just enough that it would side on and off with little effort. I think Gbox is in your state though or if you can nail down Brian that would be your best bet. Even the dealer may do it for you.
Jul 29, 2019 11:13 AM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
