Fitment issue.
Old Mar 15, 2011 | 02:00 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Fitment issue.
Is there anyway this is going to fit?
the car is off the ground, so it will tuck some due to camber, but I dont think its going to be enough?!?
Old Mar 15, 2011 | 02:11 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Well, really don't think so unless you transform your car to be a "monster" 996TT.
Old Mar 15, 2011 | 02:30 PM
Boostin's Avatar
Boostin is infamous around these parts
What is the width and offset? I have seen a 12" with et20 on a widebody 996 so I know it can be done. Camber on that car wasn't ridiculous either. I just picked up some 18x12s with et25 but haven't had a chance to test fit them yet. You will definitely need to have your rear fenders rolled if you haven't already. With enough camber anything can fit! ; )
Old Mar 15, 2011 | 03:09 PM
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
very very aggressive!!! have you considered having the hub milled down to increase the offset? or get new wheels!
to put it into perspective im on 11" rears with et36 with 315 tires.. im debating whether or not i need to roll my fenders.
i am planning to back the car up onto a curb with one wheel to get the wheel tucked in at maximum compression and see if it rubs the fenders...
Old Mar 15, 2011 | 04:15 PM
LO_996tt's Avatar
LO_996tt is infamous around these parts
I would be very careful about driving before you get the fenders rolled or the hubs milled. I thought I could be careful...but my first drive in my neighborhood I hit a small dip in the pavement and the fenders cut the sidewalls terrible. Since then I dumped my spacers and got new tires.
Old Mar 15, 2011 | 04:29 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Off-set information would be ideal to post, given the angle of the photo/car on the lift etc. it will be a little hard to make the final call...
How wide and off-set..
-Eli
Old Mar 15, 2011 | 09:28 PM
-Eli
they are iforged classics. Is the offset stamped anywhere on them? Can it be measured?
fronts are 19x8.5
rears are 19x11
Old Mar 15, 2011 | 10:14 PM
19x8.5 +40
19x11 +35
I am a little less nervous now, the person I purchased from has assured me they fit perfect on a 996tt. I should have searched offsets before posting, just seeing 1/2" of the wheel past the fender scared me, I dont want to look like a stretched ricer.
Old Mar 16, 2011 | 04:35 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
You got at least another 1" of wheel and +7mm offset available to you you will be fine !
Old Mar 16, 2011 | 08:02 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
11x19 and +35 should post no problems if they really are +35. That's only 10mm more than the regular ET45, which in turn is less than an OE GT2 wheel that fits right on being 12mm wider inside and outside. Plus you can add a 7mm spacer on GT2 wheel totalling 19mm wider. Then you still have margins (at least with rolled fender).
albert@velosdesignwerks
996 Vendor Classifieds
Oct 11, 2015 08:37 PM
Cayenne 958 Vendor Classifieds
Sep 10, 2015 02:02 PM
Sep 10, 2015 01:44 PM
Panamera Vendor Classifieds
Sep 10, 2015 01:43 PM
Sep 10, 2015 01:40 PM
