NEED Frame Specs asap
Old Mar 21, 2011 | 07:28 PM
hasauto's Avatar
hasauto is infamous around these parts
I am building a salvage 911 TT that was smacked at the track in the front and back right!
My guy at the body shop is not able to find any of the specs on this chassis. And porsche wont release any info!
Does anyone know all the specs with the X dimensions under the car?
thanks a million!
Tyler
Old Mar 22, 2011 | 02:50 AM
jpflip's Avatar
Is it what you are looking for ? Page 195 of the repair manual. And for the manual simply look at $manager post here: https://www.6speedonline.com/forums/...p-manuals.html
Old Mar 22, 2011 | 05:10 PM
Macster's Avatar
thanks a million!
Tyler
I believe you'll find the info you need at the Celette Bench company web site.
Celette is the alignment bench used at the factory to align/assemble these cars to ensure the body/chassis/tub diminensions are within factory tolerances (which are quite tight).
When a car is repaired and the body/chassis/tub is suspect of being 'bent' the car is stripped of its running gear and put on the Celette bench. The necessary jigs/fixtures are rented from Celette. This is to everyone's advantage cause it is Celette that alone is responsible for ensuring all the jigs/fixtures are kept in good repair.
All the body/chassis/tub hardpoints are checked for proper location and if any are found out the bench or the floor where the bench is mounted is used to anchor pullers that are used to pull the various body/chassis/tub hardpoints into proper location.
Sincerely,
Macster.
Sincerely,
Macster.
Old Mar 22, 2011 | 07:11 PM
hasauto's Avatar
Thanks a lot JPflip,,, frame work went great and everything is straight!!!!
Now time to put back mechanics, then paint.... just in time for spring!!
Old Mar 22, 2011 | 08:49 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Pics!
Old Mar 23, 2011 | 02:22 AM
jpflip's Avatar
Where are you in Montreal?
Old Dec 4, 2020 | 11:14 PM
Moe Marmash's Avatar
Moe Marmash is infamous around these parts
Smile
Hey Guys
I have a similar issue, my 2002 996 Turbo got in a little accident while my brother borrowed it for an afternoon ride, front passenger side hit. It seemed like the fender got hit in abit as well as the rim and control arm. All changed to new, now the car sits a little higher on the right. should I be suspecting chassis damage? is there a way I can check myself before taking it to a shop?
PV=nRT.
Sep 9, 2022 06:06 PM
PelicanParts.com
Sep 11, 2015 02:46 PM
PelicanParts.com
BMW Vendor Classifieds
PelicanParts.com
Audi Vendor Classifieds
Sep 9, 2015 03:29 PM
PelicanParts.com
Classic Porsches
Sep 4, 2015 03:30 PM
