PCCB Pad Wear
Old Mar 24, 2011 | 07:34 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
PCCB Pad Wear
At 12k I'm down to 55f% and 50r% rear pad wear. Doesn't seem to excessive given driving style. How many pad changes are the PCCB rotors typically good for?
Old Mar 24, 2011 | 08:54 PM
Tim941NYC's Avatar
that seems a bit excessive. I do heavy stopping from deep in the triple digits and get plenty more miles then that. The claim is 100k before 1st service. I know that's not true though. Plus I get plenty of brake dust too!
Old Mar 25, 2011 | 12:30 AM
Duane996tt's Avatar
Funny I get barely any brake dust. I must be harder on the pads than I realize.
Old Mar 25, 2011 | 10:57 AM
ChrisGTS's Avatar
ChrisGTS is infamous around these parts
Mine don't dust at all. Not sure how long the pad life is supposed to be, although 100k miles seems like an awful lot for pads. I know the rotors are supposed to last "forever," but I wasn't sure that applied to the pads.
Old Mar 25, 2011 | 11:37 AM
Superfly's Avatar
Superfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant future
Don't know what the pad wear is, mine are still in great shape. Rotors are supposed to be "lifetime" items.
As for dust, I've got ZERO from the PCCB's in all the years. Tim, have you replaced your pads? Did you use the Porsche ones for the PCCB's?
Old Mar 25, 2011 | 07:34 PM
Tim941NYC's Avatar
Yes I did. The first set where about 65% and when I took then out I could see brass studs that help to bond the pad to the backing plate. The box had a Porsche part number but where stamped with pagid on the backing plate.
Old Mar 26, 2011 | 12:52 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
37k miles, my pads barely worn, not too hard on her though. I only hear the dust; the brakes squeal I rinse off the brake/wash the car.
Old Mar 26, 2011 | 08:52 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
aren't the pads supposed to be swapped out at 50% so the rotors last long?
Old Mar 26, 2011 | 07:20 PM
Duane996tt's Avatar
My indy mech says the pad wear lights should save you from dragging a rivet but to keep up with pad inspections. Pads are cheap compared to the rotors so I'd apply an abundance of caution by conducting visual inspections more frequently.
Old Mar 26, 2011 | 08:17 PM
Tim941NYC's Avatar
Pads, front 800ish rear 600ish. Rotors 4,500 each
Old Mar 27, 2011 | 01:54 PM
Danyol's Avatar
I did replace the antivibration shims in there, the adhesive is useless after a few years.
$800 for a ser of pads
BTW, my Audi Q7 has calipers that are almost identical, many of the parts are interchangeable. Last time I did the Audi I used lower dust (I think composite ceramic of some sort) aftermarket as the originals produce tremendous dust. EBC redstuff I think, maybe they make a compatible ceramic for the Porsche.
Doing a little reserch, they list a 996 TT ceramic rotor application, if they really are it will be a good cheaper alternative.
Goonie
Sep 12, 2015 02:10 AM
GSP
Sep 9, 2015 05:31 AM
Nuke
Sep 8, 2015 09:09 AM
