Window Regulator
My drivers side window has stopped working
It makes a grinding noise, so i'm guessing the motor itself is still ok
How long should I expect to spend replacing the regulator?
Are there any other parts that need changing whilst i'm at it? - door seals/membranes, etc?
OK guys,
I finally got around to replacing my broken window regulator
It took me about 2 hours from start to finish as I work pretty slowly......I reckon if you were really going for it you could easily knock at least 30 minutes off my time
Here's a link to the DIY I followed......I thought I'd post the link here as it's a far better write up than I could have done
Anyway, that's enough talking, here's the link.......
http://www.bombaydigital.com/boxster/projects/window/
No worries, and yeah it's not hard at all
The most difficult bit is removing interior trim clips without holding your breath and closing your eyes whilst waiting for something to snap
I always have a horrible feeling when working on interior trim that i'm going to snap the clips and tabs when I try to remove them
No dramas today though, plain sailing all the way
Seems like me and you have twin cars with the same problems. I need to replace mine just haven't had the time to do it. Now it looks like I have a nice DIY to follow when i get in there! Thanks!
I put it off for a while, but now it's done I know I should have done it much sooner, it's no problem to do and you don't need any special tools or skills
When I took my old one out I found that the 'wire rope' that rolls through the rollers had just snapped in half
The motor was still working, which meant when I tried operating the window the motor would pull the wire inside it and get all tangled up.......difficult to explain, but you'll see what I mean when you get in there
I'm attempting to do this today and noticed that the door pull is a single piece as opposed to the pictures that show one piece around the door release handle and one piece for the pull. I have the carbon fiber door pulls. I am trying to do this gently so that I don't damage the carbon fiber, is there a way to pop this off easily that anyone knows?
TIA
TIA
TIA
TIA
Actually, it was just that I had to pull on it and release the clips. There were 5 clips on the door pull alone, so it is on there pretty good. If it was just plastic, i would have just pulled really hard, but since it was the carbon fiber, i wanted to be extra careful.
For anyone else with a 2001 like myself, there are also 2 screws behind the speaker grille that hold the door panel on. You have to remove the little "Porsche" emblem on the speaker grille (glued on) and behind that is a allen screw, remove that and the grille comes off. Then pull out the 2 phillips screws that are about 2.5" long and the panel comes the whole way off. That took me a little while to figure out as well as the Boxster doesn't seem to have that.
Now that I have it done, is there a way to adjust the amount of drop that the window does? THe new regulator only drops it about 1/4", just enough to get under the window frame. On the other side, it drops a good 1/2" or so. I tried pushing the window down slightly thinking that maybe the window was getting stuck, but it is solid. I just wish it would give a little more clearance.
I did the reset procedure of holding the window closed and open for 5 seconds as well. Didn't seem to change it.
