LSD in an AWD car
Lots of misinformation in this post.
The 996 has a pretty primitive PSM by today's standards. From what I've seen The factory PSM does not do any torque vectoring or LSD function via braking under power. When it's turned off it's off unless you hit the brakes then it turns on. When activated, it cuts out the throttle and brakes individual corners to bring the car back in line.
The viscous coupling AWD system does not send a lot of torque up front despite Porsche's claims of "5-40%". You will be be hard pressed to see the AWD spin all four tires in the snow let alone the tarmac. The idea of a 4 wheel burnout in a 996 is just fantasy.
This video is very typical of many 996turbo in the snow videos. The wife is impressed, but the front tires do 0 spinning.
http://www.youtube.com/watch?v=zy7cMZe1JAk
Even more proof
http://www.youtube.com/watch?v=ETG1x...eature=related
Even more proof
Is that awhp or rwhp? Dynojet numbers?
Pending what types of numbers those are, a good set of tires like an NT-01 or V710 will give you all of the rear grip you need. Tires like an R6 will give up the grip long before they cord and you could be skating around in no time. R888's are ok, but the tread deep tread makes them less stable in the rear and on many applications slower than the NT-01 (similar compounds) Street tires will give you some grip issues, but mostly I've found street tires to provide less front grip and the rear is still ok, so you'll get far less grip on turn in so you need so much less in the rear.
In the rain, on a track alignment, even with AWD it will be hairy, even with AWD and an LSD it will be hairy.
Your alignment will also have bearing on the grip. In the dry, the car will roll more because of more grip, if your alignment is street'ish that will be decent in the wet. If you are going aggressive on the alignment and it rains, the car will be a REAL handlful, because now you don't have the grip to roll the car and flatten the tire patch to the ground, so you end up with only part of the tire on the ground and smaller patch. LSD will make that easier to catch if the car gets out of hand.
Of course that's if you drive in the rain, I will only once or twice a year and many just won't drive.
I don't drive in the rain period, except if I'm caught in a shower on the way home from the track. My car is still AWD. I have never been on a dyno so can't say. I'm only going by what my tuner told me as far as what the HP numbers will be. Right now I'm on K16's with a flash. It's supposed to be 490 crank HP. I'm using Nitto NT01's. Tried the Toyo's but hated the noise. I won't spend the money for Hoosiers and their short life. My alignment was set-up for the Rcompounds by my tech who used to work on the Farnbacher-Lole race team. As far as street tires go, I plan to flash back to stock for street driving. The car is so much easier to modulate on the stock tune and I don't street race.
I would love to see video of all 4 wheels spinning on a 996TT. I am not questioning your knowledge on the 996TT but I have never seen a 996TT or 996 C4 spinning the front tires even in snow. That isn't to say it doesn't happen, but it seems odd that the two videos of 996TTs in the snow above show only the rear tires spinning.
http://www.youtube.com/watch?v=MozvhPnWtWM
Ok I see, sounds like you'll be making about what I'm making now. I stand by what I said. I have a LOT of video and data driving with my AWD TT and no LSD at the track, and I can count on my hands the number of times I've even had to make a correction let alone catch a tank slapper. As long as your throttle, steering and brake inputs are smooth and coordinated, you won't be fishtailing anytime soon.
If you don't get the LSD initially, let us know how the car feels after a few events. I'd like to know your impressions.
Just as an FYI, we were the OEM LSD supplier for RUF during the 996 years. If the vehicle was spec'd with an LSD from RUF, it will have one of our GT2 Pro chromoly units installed in it, usually set at a quite aggressive 50/80 locking factor.
Is the RUF with your LSD AWD?
You would know better than I if your car has an LSD in it or not. But if it does, it's likely one of ours.
