Chipped 996 Turbo - K16s vs K24s
Old Apr 11, 2011 | 05:04 PM
  #31
Prche951's Avatar
Originally Posted by heavychevy
And end up with some bloody knuckles!!!
it pays to have friends that have small hands and stick arms
Old Apr 12, 2011 | 08:54 AM
  #32
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
Originally Posted by ColoradoSilver
I'm surprised that you're seeing 525 hp consistantly with stock DVs. I'm at about the same hp numbers and I was having issues with the stock DVs bleeding. Switched out to billets and have never had an issue since.
Once you're running anything over 0.8 bar boost, upgraded DVs and F-hose are almost a mandatory supporting mod.
Its a relatively cheap mod that will give you great piece of mind. Get it done!
The install can be a PITA as it's pretty tight in there, but you'll figure it out as most of us have.
I guess I have no idea if my power is consistent, as I have no frame of reference or comparison and otherwise can't decipher an issue.
What do you mean I'll get "great piece of mind" from diverter valves?
Old Apr 12, 2011 | 09:03 AM
  #33
johnspeed's Avatar
HI,I ran for a long time 1.1 bars on my original 1st mod,GIAC tune,with no DV problems...But later I did change the DVs which is a piece of mind because they do fail ...But now I have had 1.3 to 1.4 spikes with my K24/18 set-up and I still have a factory F hose,as do some that I know at this level,with no problems.....But I guess that has alot to do with the install of the DVs and making sure the clamps are on right and tight.....
Old Apr 24, 2011 | 08:55 PM
  #34
Smoltz's Avatar
Smoltz is infamous around these parts
If everything goes well with the PPI, I'll be picking up my 996TT X50 this week :-)
Thanks for the input everyone.
-Adam
Old Apr 25, 2011 | 04:56 PM
  #35
VAGscum's Avatar
As many others here have stated, with an X50 car, just a flash and a good exhaust will knock out most of the lag. The upper end really pulls hard with the K24s where the K16s run out of breath a bit more at the top end.
That being said, if you're buying a turbo 996, it's hard to lose no matter what you end up with.
I just moved to Ft Lauderdale from Denver and I have to tell you that the running out of lungs thing seems to only be noticeable in the higher altitudes. The lungs are very healthy all over here and pretty much anywhere up to 2k feet.
BTW if you haven't found an independant shop there, talk to Randy and Todd at Autobahn Premier service. They are great mechs and awesome guys to deal with.
BlackMarketRacing
Dec 8, 2015 01:49 PM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
