Highest hp K24 Car?
Old Apr 8, 2011 | 02:09 PM
  #31
LUISGT3's Avatar
Originally Posted by bmoores
Luis if you are talking about the guy who claims to be making 844whp on stock K24s please pass the message along that I will pay to have his car sent to the dyno of his choice as well as pay for the dyno pulls and fuel if he really says he can make 844whp on a non modified K24.
Ben.
That's the one. I wanted to pass along a real discussion on people that actually know what they are talking about. It seems that the concensus is that the limit of K24's is around 520whp, correct?
Old Apr 8, 2011 | 02:35 PM
  #32
AtomicZ's Avatar
AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !
Ben.
Ben -
I made this offer locally and never heard back. To be fair I didn't offer the dyno of his choice since his dyno read 844rwhp already.
I even offered to run him in the GT2 on wastegates and pump gas.
Old Apr 8, 2011 | 02:50 PM
  #33
LUISGT3's Avatar
He should slaughter your Z06, you should run him in the stock Z.
Old Apr 8, 2011 | 03:46 PM
  #34
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Luis your assumption is correct based on the 6+ years I have been a keyboard warrior.
Old Apr 8, 2011 | 04:10 PM
  #35
johnspeed's Avatar
With stock K24s,,I made 505 rear wheel HP on a Dynojet with GIAC,93 oct map,DVs,K+N filter and Cargraphics muff/cats{I have that system for sale..lol..}
Old Apr 8, 2011 | 05:07 PM
  #36
Zeroh's Avatar
Zeroh has a spectacular aura aboutZeroh has a spectacular aura about
Originally Posted by Prche951
any idea what the highest hp K24 car can do a 60-130 in?
Thats the real question !! Have any K24 stock turbo cars gone sub 8s on pump ?? Mine is low 8's on pump (Vpower) but can't crack it with tune 200cell cats and headers... no upgraded wastegate springs tho.
Old Apr 8, 2011 | 05:20 PM
  #37
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Originally Posted by 2muchtime
mine with supporting mods before Chris needed to add another fuel pump ran 619 whp with 50/50 and 93 octane
Yes, but meth does all the difference in the world IMO...
In fact Audikp did 600+ with stock IC and inlets, but with 3071 and 50/50 meth inj..
On straight 93 pump fuel, Tony's words, " I guess about 650 crank with some room for more if you want later"... (refferred to my setup)
Old Apr 9, 2011 | 07:34 AM
  #38
Prche951's Avatar
Luis, I think I have found the answer for you in a roundabout way. The link below discusses the differences between the K24 and K24/18g, and basically the gist is that the K24 flows 32.4 lbs/min and an 18g flows 40lbs/min. So if I interpret it close, if an 18g can do 800 whp, then under the same conditions a K24 would hit 650 whp. The only thing I don't know is over spin, and if the stock turbos have a max below that. But from that thread it is obvious that K24's cannot go to anywhere near what an 18g does. Hope that helps:
https://www.6speedonline.com/forums/...different.html
Old Apr 9, 2011 | 10:09 AM
  #39
LUISGT3's Avatar
Thanks Dennis. That's a great thread. Either the car in question has different turbos than stock K24's or the dyno that it's being tested on is off by a significant margin.
Old Apr 9, 2011 | 10:13 AM
  #40
LUISGT3's Avatar
For anybody interested, here is the dyno for this "stock K24" turbo car.
Old Apr 9, 2011 | 10:23 AM
  #41
Divexxtreme's Avatar
I'd day 520-550 whp depending on the dyno being used.
Old Apr 9, 2011 | 10:29 AM
  #42
I don't see 840 whp listed anywhere, just 686. Looks like he's using a 22.5% correction factor on top of the 686 whp dyno number to come with 840 crank HP (also inaccurate).
The dyno also claims 686 whp was made at only 1.1 BAR. It would take a built motor with heads, cams and GT35's to make that much power at only 1.1 BAR. Obviously, everything about this complete bull*hit.
Old Apr 9, 2011 | 10:31 AM
  #43
LUISGT3's Avatar
This is actually a 2nd run that shows more "accurate" #'s. I dont have the 844whp sheet, but that was the original claim.
Old Apr 9, 2011 | 10:41 AM
  #44
Well, at least they're getting closer. They only need to manipulate their dyno to drop another 150-180whp and their story might actually start becoming believable.
Old Apr 9, 2011 | 10:42 AM
  #45
LUISGT3's Avatar
By looking at the graph, does that look like the way a stock K24 car pulls?
