Spacer Help Please - new BBS LM's
Old Apr 14, 2011 | 10:42 PM
///M_Chap's Avatar
///M_Chap is a jewel in the rough///M_Chap is a jewel in the rough///M_Chap is a jewel in the rough///M_Chap is a jewel in the rough
Hey guys,
So I just bought a set of LM's for the Turbo (hadn't had a set of LM's since my E39 M5 and I really love the way they look on a 996tt) and I wanted to see if you could help me with spacer sizing.
fronts are 19x8.5 +55
rears are 19x11 +63 (they were running a special on these and not the +50's which is why I went with +63 offset)
I put a 15mm H&R hubcentric on the rear but it's not even close to filling out my rear wheel well (I'm lowered on coils as well)
H&R hubcentrics come in 7, 14, 15, 23, 30, 35.. for 996tt applications
I'm thinking about putting the 15's up front and probably a 23 in the rear. The 15's may be too much for the front but since I already have them I'll give them a shot.
Any advice would be greatly appreciated!
Thank guys
Old Apr 14, 2011 | 10:47 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
I'm no expert but 23 should work on the rear. Whatever you decide, post some pictures when its done!
Old Apr 15, 2011 | 12:05 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
If you want aggressive offset, you can run 8.5" ET45 front and 11" ET25 rear on 996TT. That means you need 10mm spacers front and 38mm spacers at rear each corner.
Old Apr 15, 2011 | 07:10 AM
I Rune ET45 front and ET35 rear on my 19" VS-XXs, I rolled the rear fenders. Rear is pretty flush at ET35. Mine are 12s though. I would say do the 30mm spacer for nice fittment. I wouldnt go any bigger because you may rub on the outside.
#TeamAIM
Old Apr 15, 2011 | 07:11 AM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Go 30mm in the rear, 10 mm in the front should work well too. If you dont mind me asking, could you PM what you paid for those LM's. I love the way those wheels look too.
Old Apr 15, 2011 | 07:12 AM
LiNks's Avatar
Prodigy that gemballa wing looks goood!! For some reason yellow and red are the only colors I see that lid work on.
Old Apr 15, 2011 | 07:46 AM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
I'm running:
8.5 x 19 ET53 w/14mm spacer - effectively an ET39 (235-35/19)
12 x 19 ET51 w/7mm spacer - effectively an ET44 (315-25/19)
No rubbing and they both fill out the wheel wells equally and nicely - fenders are not rolled.
Old Apr 15, 2011 | 07:50 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Depening on your tire sizes or brands, they do make a little differences. I say you can easily run 11mm front and 26mm back. With my HREs (being resealed/refinished), I was running +39 front and +28 rear (w/9mm spacer).
Old Apr 15, 2011 | 12:01 PM
pwdrhound's Avatar
7 in the front (et 48) and 30 in the rear (et 33) is perfect. Any more than that and you will most likely rub especially in the rear if you are lowered. I run et 50 front and et 35 in the rear with rolled fenders on RUF 19/8.5 and 19/11. I am at GT2 rideheight and do not rub but it's tight.
Originally Posted by ///M_Chap
Hey guys,
Thank guys
Old Apr 15, 2011 | 12:59 PM
///M_Chap's Avatar
Thank you all very much for the help!! So you think running a 14 in the front (et 41) will be an issue? Fenders will all be rolled and I'll prob be a bit lower than GT2 ride height.
I'd like to have an aggressive offset but I don't want to sacrifice driveability and performance (function over form).
Old Apr 15, 2011 | 01:10 PM
that will work. you will def want to roll fenders a bit at that height.
#TeamAIM
Old Apr 15, 2011 | 03:12 PM
SY6TTX50's Avatar
SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !SY6TTX50 Is a GOD !
Originally Posted by prodigymb
Wow, she looks great, good job man...
Old Apr 15, 2011 | 03:43 PM
pwdrhound's Avatar
Based on the clearance I have on a lowered set up (25.25" to the fender in the front) on a 19x8.5 et 50 with 235/35/19 PS2, when I'm at full turn (full steering wheel deflection) the edge of the tire gets REAL close to touching the fender liner. Any more aggressive and I think it would hit. My opinion is that et 41 will rub in a tight turn. You can see the et50/35 offset on 19x8.5/11 in the attached pictures. This set up does not rub in any situation on 235/35 and 315/25 tires.
away
Apr 27, 2016 03:53 AM
Boldgt
Mar 23, 2016 11:07 AM
djhill
Oct 29, 2015 07:04 PM
johnnyg996
Sep 30, 2015 11:19 PM
Pcar991
Sep 29, 2015 05:20 AM
