hard clutch pedal
Old Apr 16, 2011 | 02:12 PM
snopdog911's Avatar
snopdog911 is infamous around these parts
hard clutch pedal
my clutch pedal use to get hard after a few days sitting,
but the slave is not leaking. how long before it goes?
what else can be the cause?
maybe I should just do the gt2 mod!
Old Apr 16, 2011 | 03:32 PM
X98boardwell's Avatar
X98boardwell is infamous around these parts
If you can change now do it... it won't get any better. The accumulator is normally the problem but it also makes sense to change the slave cylinder if you can (it makes it harder and is about $500 more expensive).
The accumulator actually doesn't leak... it will leak out of your front resivoir and spill to the ground where the hole allows for that area to drain. It is also a PIA to clean up once it leaks... ask me how I know. They go out at all different times and mileage. My car had 8,000 miles when it went out but it wasn't driven a lot which may have contributed to it's demise. I replaced both myself in about 4 hours total. Like building a boat in a glass bottle with your eyes closed. Also make sure you have the right tools prior to starting if this is an option for you.
Best of luck with the fix,
Bryan
Old Apr 16, 2011 | 06:46 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
My 996 Turbo is extremely stiff after sitting a few days, which happens a lot (single dad with kids and my STI is the kid car). It may be normal.
Old Apr 17, 2011 | 03:17 PM
SRISER's Avatar
SRISER has a spectacular aura aboutSRISER has a spectacular aura aboutSRISER has a spectacular aura about
My pedal was stiff after the car sat for about 6 days. Then, after sitting another 6 days it was soft as butter. I dunno...maybe nothing...maybe the accumulator (original) finally taking a crap. My slave was already changed a few months ago so I actually hope the accumulator fails on my car as I am still under warranty. Free replacement. :-)
Old Apr 17, 2011 | 03:23 PM
Centauro97's Avatar
Centauro97 is a jewel in the roughCentauro97 is a jewel in the roughCentauro97 is a jewel in the roughCentauro97 is a jewel in the rough
I had the same problem, changing the slave and accumulator fixed it.
Overflow of the reservoir and hard to press the clutch until the engine was started.
Old Apr 18, 2011 | 12:59 PM
XLR82XS's Avatar
GT2 slave conversion and don't look back.
Old Apr 18, 2011 | 07:51 PM
Macster's Avatar
Ditto for me and my 03. Pedal was hard to press after car sat overnight. Then a few weeks later signs of clutch fluid leaking from reservior under panel under front trunk lid. Dealer replaced both accumulator and clutch slave cylinder (under CPO warranty!) and clutch easy to press and all is well again.
Sincerely,
Macster.
jaehoppa
Oct 22, 2015 09:17 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
Saint Ari
Sep 4, 2015 03:30 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
