Braking Noise?
Old Apr 22, 2011 | 07:04 PM
intothewild1's Avatar
intothewild1 is infamous around these parts
Braking Noise?
Does anyone know what is causing the high pitched rubbing noise? I have Brembo RACE System brakes with relatively new Ferodo pads. When I changed the pads, I didn't change rotors because the rotors seemed like they had some good life left. During the first part of the session, there is no noise whatsoever. As the session wears on, the noise becomes quite loud. If you listen carefully, the noise occurs even when I'm off the brakes, but it's worst under heavy braking. Near the end of the session, the brakes are smoking. I've had a few people suggest that it could be tires, but that doesn't make as much sense to me. No one at the track seems to know and the guys at the brake shop think I need new rotors. Anyone with ideas?
http://www.youtube.com/watch?v=9_UJsjANA0I
Old Apr 22, 2011 | 08:31 PM
btapp's Avatar
btapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of light
Sounds like a warped rotor to me.
Old Apr 23, 2011 | 07:35 AM
landjet's Avatar
Wheel bearing? Never heard that kind of sound before.
Old Apr 23, 2011 | 08:20 AM
raineycd's Avatar
Def an odd sound for brakes to make. Def check the rotors and look for any rubbing - almost sounds like tires rubbing on plastic.
What exhaust do you have - sounds great!!!
Old Apr 23, 2011 | 10:05 AM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
Almost as if the calipers aren't releasing completely? Just shooting in the dark here.
Old Apr 23, 2011 | 10:07 AM
landjet's Avatar
Are you sure the noise is coming from your brakes? Since it is always under deceleration, I wonder if it could be a diverter valve diaphragm fluttering. Just thinking out loud.
Old May 16, 2011 | 06:37 PM
Pad Guide
From my mechanic...
"We found a piece of the brake caliper that has been rubbing on the rotor…stainless steel pad guide not centered."
Old May 16, 2011 | 08:16 PM
Aerodude's Avatar
Originally Posted by intothewild1
From my mechanic...
Glad you found the problem. No damage to the rotors?
Old Apr 17, 2012 | 11:02 AM
Braking Noise Back
After a long hiatus from the track, I returned recently to find that my braking noise has come back. It only takes a few laps to warm up the brakes, and then the noise returns. Maybe it is the new Ferodo pads? I don't think I had the problem with the Brembo pads.
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
