MSD 72lb injectors??
Old Apr 24, 2011 | 09:46 PM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
Hi guys, will these injectors fit a 996tt. Apparently they are a direct replacement for the stock BOSCH injectors. http://cgi.ebay.co.uk/MSD-2014-Fuel-...item1e6314a55c
Thanks!
Old Apr 24, 2011 | 10:26 PM
Turbo Fanatic's Avatar
I would ask your tuner first. Seems like Tony at EPL likes to use 72lb injectors in combination with a 5 BAR fuel pressure regulator.
Every tuner has their own tried and tested setup. I would just follow the beaten path after consulting with your tuner of choice first ...
Old Apr 25, 2011 | 07:02 AM
Tim941NYC's Avatar
No good. first off there are low impedance (2ohm) stock dme uses 12ohm. Second off there are only 4 for sale.
Old Apr 25, 2011 | 09:27 AM
Yazz911TT's Avatar
So if i can get them in 12ohm will they fit? I know the auction is for 4 but i contacted the seller and he has 40 in stock. So he will sell me 6.
Old Apr 25, 2011 | 09:48 AM
Tim941NYC's Avatar
http://www.fuelinjectorconnection.co...ewCat&catId=72
I do not know the company or have ever bought anything from them, just showing the injector to buy. You will need to mod the fuel rails.
Old Apr 25, 2011 | 09:57 AM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
I would use an injector your tuner recommends. I've used RC and ID. I know Siemens work good as well. My old injectors were ID 1000cc and my new are ID 1600cc. All of them are High Imp. injectors.
Old Apr 25, 2011 | 10:10 AM
Yazz911TT's Avatar
Is it the Bosche EVI4's?? as the link shows quite a few injectors. also, what exactly needs doing to the fuel rail. I cant contact a tuner about this as none of them here in the UK know about changing injectors on a porsche. So i am getting the mods done myself by a porsche tech first then just going to the tuner for a map.
Old Apr 25, 2011 | 10:40 AM
Tim941NYC's Avatar
Nope the top two. They fit the same plug as the factory injector. They are a tad bit longer and will need the fuel rail to be modded. Some guy's sell spacers other weld a piece on the mounting pads to add the distance. I weld on as the fuel psi and boost psi are trying to pop the injector out.
Old Apr 25, 2011 | 01:56 PM
instead of pulling your hair out... here is what we have.. it works with our injectors- no drama... we run 630 cc injectors for entry level kits on a stock FPR...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 25, 2011 | 05:23 PM
Yazz911TT's Avatar
How much does this cost?? Thanks.
Old Apr 25, 2011 | 05:46 PM
Here is a link....
http://www.911tuning.com/996-Turbo/-...tem--c-59.html
9.66
click to view
Old Apr 25, 2011 | 06:36 PM
Yazz911TT's Avatar
Thanks for all your help guys! Can I ask, what would be the effects of installing 72lb injectors on a stock car??
Old Apr 25, 2011 | 09:06 PM
Tim941NYC's Avatar
It will run rich. The ecu will pull some fuel trim to try an lean it out all on its own. If you are asking to have the injectors installed then drive it to get tuned the answer is yes you can.
Old Apr 26, 2011 | 09:30 AM
Yazz911TT's Avatar
Well I wouldn't have the money for a map for a few months after. I guess it will flood the engine with fuel by then.
Old Apr 26, 2011 | 10:15 AM
Tim941NYC's Avatar
LOL. I can not remember fully but I did see a car that had a evoms 700 kit in it that was flashed to stock by the dealership. It was going into limp mode do to the wastegates making more boost then the stock program would allow. I think the cold start was very rich then smoothed out.
