durametrics stuff
durametrics stuff
i have just hooked up the durametrics cable to my car (2002 TT) for the first time, and don't really know what i am looking at with some of these #'s et al, can someone tell me where to find explanations? one thing, how do i find the overrev #'s...is that the ignition range 1 and 2 #'s? i am looking forward to learning about this beautiful beast, and driving it, thanks in advance, kk
I could not found any instruction of any kind. After playing with it I've learn the many functions. Yes ignition range are the overrev. Type 2 is the one to look for. Are you using version 5 or version 6 ?
hi, i don't know if i have version 5 or 6, the durametrics cable and instruction cd came with the car, and it says there are no type 2 ignition range overrevs, so thats good, i will see if i can download version 6, thanks for your help,..kk
If you used the search engine you will found a lot of informations about type 1 and type 2 overrev. Type 1 is less critical because the counter start as soon you hit the max revolution which can be done easily in first gear, but type 2 can be a miss shift...
https://www.6speedonline.com/forums/...over-revs.html
https://www.6speedonline.com/forums/...-read-out.html
Remember version 6 is still a beta and some functions are not working properly.
I very good function to learn about is "drive link" which aloud you to troubleshoot car systems like vario cam, air pump, cooling fans etc. There is a lot to learn....
