The Next Logical Step for the RED ROCKET
Old May 13, 2011 | 01:30 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Given your "tech" attitude, I'm sure you'll make it work just fine!! I wish you best of luck. And I would be extremely curious to know about your progresses along the way.
Old May 13, 2011 | 01:44 PM
jpflip's Avatar
Tim , this is getting wayyyyyyy over my knowledge. I'm still trying to figure how to reprogram my transponder with the PST2
You are hot! Of course keep us up to date with this new adventure!
Old May 13, 2011 | 02:03 PM
Tim941NYC's Avatar
Originally Posted by Powell
Tim you took my idea!!! That has been the hardest process of this build was figuring out how to shoot at LEAST 10ft flames!!!
LOL... I am thinking about putting up a detailed thread about the whole process. I have to open up the motor to cut bigger valve reliefs in the pistons so I can snap some pic's and point some things out along the way. Also many minds are better then one so your input would be good too.
Old May 13, 2011 | 02:16 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Just program your Motec to run nitromethane. You will have a flame throwing beast on your hands. Good luck with your project. Sounds like great fun.
Old May 13, 2011 | 02:27 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Tim anything I wouldn't be able to answer I am sure Justin would be willing to share some of the information with you (if you come across any hang ups). I know Motec was one of his original choices on his car (the first Tuning Concepts 996TT "Standalone" (put with quotes because there has always been a debate about that term being used and many not knowing the diff. between how a Standalone and Piggy Back handle information)). He ended up using the FCon on his car, which is what is on mine as well. I think the biggest reason was initial cost. Watching and helping do the install in my parents garage at from 12-2am on one of the coldest nights we had seen in 10 years made it even more interesting. Esp when we went to fire it off and realized I had the straight pipes on the car. Exhaust swap at 3am with the garage open to that environment is not fun at all.
Old May 13, 2011 | 02:41 PM
If my car was red I'd get one of the GT2 RS *****
#TeamAIM
Old May 13, 2011 | 03:41 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Tim - I've got a spare patch harness here if you don't want to deal with cutting into your factory harness. Also make sure you get some Audi ignitors, that's one of the trickier parts of the process to figure out.
Depends how crazy you want to get on your anti-lag settings 3-4ft is the norm though....
I would call it more of a cylinder heat ejecting beast
Old May 13, 2011 | 05:38 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Interesting Project! I am subscribed
Good Luck
Robert
Old May 13, 2011 | 08:42 PM
Tim941NYC's Avatar
[quote=onelove;3203920]Tim - I've got a spare patch harness here if you don't want to deal with cutting into your factory harness. Also make sure you get some Audi ignitors, that's one of the trickier parts of the process to figure out.
Thanks Wes. I will call you Monday. I did a audi and had to change the coils because of weak spark. I am looking at Motec coils now.
Old May 13, 2011 | 08:49 PM
Tim941NYC's Avatar
That there sounds like fun, almost.. What pushed me to use MoTec is I have great support from trusted guys. If Justin was on Long Island I would run a FCon too.
Old May 14, 2011 | 08:44 AM
onelove's Avatar
[quote=Tim941NYC;3204149]
Not so much the coils, but if you hand over control of the ignition to the Motec (which you likely will) you'll need to wire in Ignitors just to get the coils to fire, factory coils should work just fine once you do this). It's been a while since we did our car so I don't remember all the specifics off the top of my head but have notes written down at the office.
Old May 14, 2011 | 09:27 AM
atisvt99's Avatar
atisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant future
This is gonna be a sweet setup, Tim... You hoping to finally break 520awhp with this beast???
Old May 16, 2011 | 04:13 PM
Tim941NYC's Avatar
LOL.. I have my fingers crossed... Ordered all the valves, springs, locks and keepers. No date for delivery as of yet.
MurderedTurbo
Aug 28, 2015 09:06 AM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
