P0300 and P0301
P0300 and P0301
Under full boost today I threw P0300 and P0301 codes. I understand what they are and what is likely the cause.
What I don't understand is why I had a blinking CEL (with drive to nearest shop..) for about 30 seconds - 1 minutes. Then both the messages and CEL disappeared. On the way home (before I hooked up the Durametric) I wanted to see if I was in limp and if it would happen again. Nothing. Car boosted to 1.0 and feels strong as can be.
Any ideas.
TIA,
Frank
Any ideas.
TIA,
Frank
Good afternoon Frank. These fault are the most difficult one to troubleshoot. Over 10 pages each and they go from valve lift to ignition to mixture!!!! If you did not found anything wrong with Durametric may be you had a glitch of some kind, bad fuel, plug ???
Here is the answer for your flashing cel....
"If the misfire rate may lead to permanent damage to the TWC,
the Check Engine MIL flashes. If the misfire rate is no longer
reached during the first journey, the MIL goes out. If the rate is
reached during the next journey, the MIL flashes. If this misfire
rate is subsequently no longer reached, the MIL changes to a
continuous light."
TWC: catalytic converter....
0-43 page 1 of the OBDII manual.
continuous light."
JP, thanks. Just thought it was strange for the flashing CEL to just go away. Long time, hope all is well. How is Mateo?
Sharkster I have 75k on the car. Plugs were changed at 60. Flashed around 62
Hope everything is very well for you and family! Mateo is fantastic and in top shape. A very clever little kid. Are you planning another trip to the east cost this summer? Did you start your tracking season? Are you going to track with "Le professeur" Jon?
JP, Glad to hear all is well. Going to Duck, NC (Outer Banks) at the end of July. I think my 1st track date is mid-June (work has been interfering with my life all year). I am going to do my best to cross paths with Jon this year - someone needs to teach me how to drive.
