and then questions start.. I need your knowledge please!!
Old May 17, 2011 | 08:14 PM
  #31
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
for the instant you got full boost the AFRs looked better, but then straight into what seems to be limp mode (as evidenced by the sharp drop in requested boost). I would stop doing pulls at this point and get it sorted. The tune may be ok, but the DME is seeing something it doesn't like and its killing boost.
With the 1255 code, I would do a leak test (pressurizing at the turbo inlets).
Old May 17, 2011 | 08:33 PM
  #32
Savetheclutch's Avatar
Savetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud of
Ok Thank you. I am going to see if I can drop the car off at one of the shops around my area tomorrow.. I am just really freaking out with this thing
Old May 18, 2011 | 08:32 AM
  #33
Tim941NYC's Avatar
Dude you are pulling timing in the torque. It maybe the old flash with the diode soldered in the ecu. check that the line to your fpr is on.
Old May 18, 2011 | 08:38 AM
  #34
I'll check that too.. I am seriously about to cry lol I want to drive this thing into a wall and forget about it haha
Old May 18, 2011 | 08:41 AM
  #35
Tim941NYC's Avatar
Originally Posted by MARKSKI@911tuning
why does the car have, if it has it, a gt2 fuel pump? stock injectors do not need it...
you basically just have a 5 bar FPR , some old gt28s and a bunch of bolt ons...
bottom line is your car is boosting ,7 bar... something is not right.... it should be running lets say 1.2 bar or so... and your afrs are way off...
the car does not seem to be healthy as you showed the logs... wait, we forgot about your original question which is... MAF problems....
You have more then maf issues my friend...
good luck...
Very well put!
Old May 20, 2011 | 09:07 PM
  #36
update... the car had a few boost leaks, they have been fixed and changed spark plugs and it now feels great. I will run logs tomorrow
oh and the turbos are 100% tial a28s
HotRod
Sep 10, 2015 07:17 PM
gulf gt
Aug 27, 2015 10:27 AM
elite1
Aug 26, 2015 09:22 PM
