Is this really a leaking radiator or ...
Old May 20, 2011 | 04:57 PM
tbarcelo's Avatar
tbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of lighttbarcelo is a glorious beacon of light
do I just have a leaky o-ring.
Here's a pic of the upper left portion of my passenger-side radiator:
I pulled the radiator off and here's a pic of where the upper hose enters the radiator (directly behind the picture above):
I'm having trouble embedding my pics ... see last two images in this album:
Album: https://picasaweb.google.com/twbarch...eat=directlink
The crud directly below the hose connection point makes me think that I just have a bad o-ring.
I'm thinking of just ordering o-rings (and getting the rad pressure tested while I wait) and then buttoning it all up. Am I nuts?
Old May 20, 2011 | 05:07 PM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
Yea Rubber seal (o-ring) goes bad.time to replace
Old May 20, 2011 | 05:09 PM
tbarcelo's Avatar
Boy, if that's true it will save me $450. Time to buy something for the car
Old May 20, 2011 | 05:14 PM
tonka858's Avatar
you going to try and pop the tank and replace the seal?
Old May 20, 2011 | 05:18 PM
tbarcelo's Avatar
tonka - you think it is the radiator tank seal or the upper hose o-ring? I'm thinking it might be the upper hose o-ring based on where I see the crud.
Old May 20, 2011 | 05:23 PM
tonka858's Avatar
i went to look at your pictures again and there gone
Old May 20, 2011 | 07:31 PM
tbarcelo's Avatar
They should be in the thread now, but I went ahead and added the album link back. Hopefully that will work.
Old May 21, 2011 | 03:25 PM
tbarcelo's Avatar
Not sure if anyone cares, but I did an ad-hoc backyard pressure test:
from album:
It is definitely weeping out of the top of the radiator. Oh well, that's kind of what I figured. I'll order one on Monday.
Old May 21, 2011 | 09:19 PM
Tim941NYC's Avatar
You need more psi and use hot water, running water temp is 99c. I had my old ones test by a radiator re builder and he said they were good, he was wrong.
Old May 21, 2011 | 10:14 PM
tonka858's Avatar
from the looks of the pictures I would replace the radiator.
If you could find a radiator shop they will pressure test it under water..for you.
Old Jun 1, 2011 | 03:34 PM
tbarcelo's Avatar
I replaced the radiator. The job was pretty easy - including the bleed process with the Uview Airlift tool. So far, so good.
awesomebang
Jul 5, 2017 08:48 PM
Jd1368
Oct 16, 2015 09:48 AM
007 Vantage
Oct 8, 2015 08:35 PM
freddiemac
Oct 7, 2015 11:05 AM
