k16/k16g Boost Pressure
Old May 26, 2011 | 06:21 PM
dog4delta's Avatar
dog4delta is infamous around these partsdog4delta is infamous around these parts
Can't answer the question as to the "actual" gains you might expect from after market coils. However, I have my opinion, and the HP vs $ return IMHO simply is not there. At least in my case anyway. I suspect there may be a plausible reason to upgrade if you are pushing very high HP / boost levels, but even there I suspect the OEM coils can still push an adequate spark across the plug gap.
I replaced my coils with OEM Porsche parts (Beru). There was an update quite a few years ago and they are actually 997 model coils. If you can't find them for $40 EACH, send me a PM and I'll tell you where I found mine.
Old Jun 3, 2011 | 10:11 PM
difparis's Avatar
difparis is infamous around these parts
Originally Posted by daytrip00
- K16g Turbo Upgrade
- Exhaust (might do this first)
- 5 bar FPR
- upgraded DVs
- New silicone hoses (including F-Hose)
- iridium plugs (due for new plugs anyway)
- High flow air filter (that may happen earlier)
Buy almost the same kit from Dan @ Vivid more than a year.
Still amazing
Old Jun 4, 2011 | 11:51 AM
daytrip00's Avatar
daytrip00 is infamous around these parts
Thanks for the advice dog4delta. I'll probably do this when I replace my plugs...
difparis, what is your boost pressure? Do you max out at 1 or 1.1 bar. How reliable has your car been and did you need a new clutch?
Old Jun 4, 2011 | 12:09 PM
difparis's Avatar
Regular boost pressure: 1.1
Max boost pressure: 1.2 or 1.3 depending on temperature (1.3 when it's under 11°c)
The car is very reliable. I think it can handle more. Don't forget that Porsche used that old engine for the 997GT2RS (and not the new engine of the 997TT MK2 )
For the moment, I don't need to change my clutch but I don't release the first gear at 5000
You can for that bundle with no problem. I gonna love it!
YJosephTT
Mar 28, 2016 02:31 PM
Fadi
Oct 5, 2015 12:14 AM
ECS Tuning - BMW
Sep 16, 2015 03:11 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
