View Poll Results: How Many Miles before a tire change?
Less than 5000mi
14.81%
5000 to 7500mi
10
18.52%
7500 to 10,000mi
11
20.37%
10,000 to 12500
16
29.63%
12,500 to 15,000
7.41%
more than 15,000 - go you!
9.26%
Voters: 54. You may not vote on this poll
How Many Miles Do your Tires Last?
Originally posted by SilverTTCab
definitely uneven! bald on the inside, receding tread line towards the outside.
fronts look ok.
so what does that mean?
fronts look ok.
If you have a lot of negative camber, increase your tire pressure some and you can "somewhat" lessen the inner wear as you push the wear more towards the middle of the tread.
I discovered early on that if you engage in hard acceleratration on a regular basis you will lose thread rapidly, especially the rears. I am not talking about smoking the tires. The TT just hooks up without smoke but you are still leaving rubber on the road. I now measure out my acceleration blasts to save wear. It seems to work since my tires are not wearing out so fast.
There rear tires will always wear on the inside long before the outside half does. You wanted a car that handles well, so you are stuck with a 1 degree or more negative camber on the rear wheels. You can change the setting and get more tire wear but you'll have to contend with severe oversteer.
well i do alot of stupid burnouts and ****, so my back ones eh prolly about 4 months max. my front ones will last for a long time like 10 to 15K. no my question is how long do you guys run on you tires??
fronts look ok.
fronts look ok.
Originally posted by PMac
Yeah, I'm guessing he probably doesn't
(I knew you were kidding)
The outer 1/3 of my rears get to the cord before the inner 1/3 need replacing.
horsepowerfarm
Sep 10, 2015 06:09 PM
I'mAllIn
Aug 25, 2015 09:44 AM
Sterlingc1975
Aug 22, 2015 02:30 PM
