Carbonetic Triple plate carbon clutch owners. Need your feedback.
I get some vibration from the rear if in reverse or even 1st and do not give it enough throttle. I think the clutch would have been perfect if I kept on adding hp/tq but I stayed at the 650ish level so I have sacrificed some "stock like feel" to keep the clutch.
I had a 1350 and a 1550 Kg plate... changed the disks after running it at the track... not the friendliest to drive but holds... however, so do other cheaper clutches... went with a Tilton triple... no comparison.. but then its twice the money...
Unfortunately I have been told by the distributor a few months ago that they stopped making them.... need to check tomorrow...
2001 996TT 3.6L and stock ECU
I believe it was around 25mm. I cut a section of the rod out and sleeved it with a piece cromo then welded it. As for changing the plates after going to the tract not to sure about that one. What kills any carbon clutch is dirt and debris. Anything abrasive will cause carbon to sand itself away. Unless it sold there was a low mileage one for sale not to long ago in the for sale section.
Thanks for the help! I have been on the phone with Carbonetic/Across USA, they are currently sourcing pieces to build me a kit. So hopefully they have everything they needed and I can have my clutch in a month. lol
I am also thinking about cancel the order if it takes too long and get a evoms stage 4 and call it a day.
What do you guys think? Are the 2 clutch comparable as far as holding power?
They are in the same price range..
Tim you and I think alike! Triple means three and as we learned as life progressed from our childhood 3 > 1!
