Carbonetic Triple plate carbon clutch owners. Need your feedback.
Old May 29, 2011 | 10:41 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Hello Guys,
I am looking to pick up a carbonetic clutch in the next couple of days. The reason I post it here is because you guys have far more experiences with this clutch than 997tt guys according to my research.
I did some search and seems like there are numbers of people here had it a couple years back.
So, let's hear your feeback.
How is it holding up?
Likes?
Dislikes?
Thanks alot!!
Old May 29, 2011 | 11:05 PM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
I have this clutch and its great. It does have on/off feel and high engagement point but other than that no issues. When the clutch is depressed it does make a subtle noise but its normal. It has never slipped and holding up great. Hope that helps.
Old May 29, 2011 | 11:10 PM
Abby997TT's Avatar
Thanks a lot! It really helps!
I can live with the on/off feel of the engagement point as I don't drive the car daily nor in heavy traffic. I heard that if you do a force break in, the engagement point will drop a bit.
How many miles do you have on it so far?
Old May 29, 2011 | 11:15 PM
bimmer81's Avatar
Ive got 7k miles on it. The first 500 miles are horrible, you cant slip it at all its very grabby but after 800 or more it gets much better for sure.
Old May 30, 2011 | 12:05 AM
Abby997TT's Avatar
Awesome! Thanks for the feedback
Old May 30, 2011 | 12:06 AM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I have one as well and thus far it has been my favorite clutch.
GL
Robert
Old May 30, 2011 | 12:07 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
how much power are you looking at running ?
there are a bunch of these clutches in use.
which clutch are you going for ( pressure plate)
Old May 30, 2011 | 01:17 AM
Abby997TT's Avatar
Thanks guys! I wanted to get modded VTGS for a while, but now I really want to get those Alpha turbos because they are so easy to install; they can make much more power than vtgs. I haven't decided on 28 or 30 yet; I will have to talk to Todd K. first and see what he recommends.
I think there are 2 pressure plates for this clutch, 1150kg and 1350kg.
Old May 30, 2011 | 02:27 AM
There is a stronger one I forget if it was 1750kg or 1950kg
But with only 30's no reason 1350 should not hold everything you can give that clutch.
Old May 30, 2011 | 02:40 AM
Abby997TT's Avatar
yea, 1350kg one will be more than enough for me for now anyways..
Old May 30, 2011 | 08:26 AM
Tim941NYC's Avatar
Get the heaviest plate you can. Its does not change the pedal feel at all. I would also recommend going with the gt2 slave. Also if you shorten the the push rod it will lower the pedal engagement. One of the easiest clutches I every drove.
Old May 30, 2011 | 01:38 PM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
had mine for about 4k miles and love it. there is a quick way of breaking them in when you first install it. it keeps it from grabbing so hard you die out on take of pm me and i'll walk you through it
like tim said, you have to shorten the pushrod on the slave so the release point won't be so high.
Old May 30, 2011 | 02:26 PM
Abby997TT's Avatar
Guys, Thanks very much for the tips.
As for the rod to cut, which one are you guys talking about? how much should i cut it? I don't have the clutch yet, so nothing to look at now.
pinoy911tt : Is it force break in some people have been talking about here ? I guess this clutch can hold the power from Alpha 30 all day and all night.
Old May 30, 2011 | 03:19 PM
pinoy911tt's Avatar
yup, forced break in that todd k told me about. and it does hold a30's all day
i forgot how much to cut the rod but search carbonetics clutch and it should pop up on the discussion. that's exactly how i found it. you might have to read a couple of pages though
Old May 30, 2011 | 07:29 PM
Abby997TT's Avatar
Thanks, That's awesome!
I did some call around today to get some quotes for installation. both local shops quoted me 16 hours and 19 hours for install; i guess it's a really big job.
