coments on tune
Old Jun 8, 2011 | 01:19 PM
pwarnery's Avatar
pwarnery is infamous around these parts
Mr. Swed,
what kind of modifications do you have on your car? I.E Turbos, intake piping to turbo chargers, fuel pressure, 5bar or fuel injectors, exhaust? By looking at your logs and where the maximum engine load is, around 4500rpm, I am guessing the car is not stock. And since the DME doesn't seem to retard the timimg that much, at least compared to my CA 91 Octane fed engine, I wonder what octane fuel are you runing? Thanks for any info you may want to share. Looking at Durametric logs is fascinating... Thanks.
PW
Old Jun 9, 2011 | 09:13 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
subscribe
Old Jun 10, 2011 | 02:13 AM
SaintGT2's Avatar
SaintGT2 is just really niceSaintGT2 is just really niceSaintGT2 is just really niceSaintGT2 is just really niceSaintGT2 is just really nice
I like to see logs that show more than 2-3 lines per second. I am working with 60 and even that's slow by standards, most are seeing 120lines/per sec. and showing individual knock per cylinder anything else is just guess work.
Old Jun 10, 2011 | 02:30 AM
Mr swed's Avatar
Mr swed is infamous around these parts
Originally Posted by pwarnery
Mr. Swed,
PW
The car is modified with: K16/16g, 997gt2rs intercoolers, 5bar fpr, 2.5" cross flow exhaust with 100cel cats, forge dv´s, forge pressure hose´s, 997 gt3 ssk. running 99 octane RON that should be 92, 93 in US I think
Old Jun 10, 2011 | 02:34 AM
Mr swed's Avatar
I´m not sure what the max/min scantime or if its adjustble with Durametric is I´l see if I can do more loggs this weekend.
Old Jun 10, 2011 | 03:00 AM
SaintGT2's Avatar
With Durametric you wón't get much more than what your getting in my experience, but just make sure you turn everything off like wireless, bluetooth etc and close any background programs so you can maximise your sampling. You should also tick Corr. factor for BPC with knock control. You need to see if your knocking.
I should of been more clear sorry, but I don't use Duramtetric now I run UMW datalogger night and day difference.
Old Jun 10, 2011 | 04:13 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
i only analyse log around 1300hfm at this moment.....
afrs are okay ....ingition tabel looks conservative and good for us91 octane/euro95 ...but this depends on intake temperature
Old Jun 10, 2011 | 10:29 AM
pwarnery's Avatar
Mr. Swed,
can you also add intake air temperature to your next log? It is handy to see how much heat the turbos add during a pull and with GT2RS inter coolers I am curious to see temperature delta from beginning to end vs my car which has stock 996 inter coolers. I found a gas station which carries 96 octane unleaded at Infineon in CA. I plan on filling up and see what difference in timing pull if any vs 91 octane this makes on my car. Ruf 520 engine kit.
Old Jun 10, 2011 | 03:54 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
EPL offers an high speed datalogger.
Old Jun 10, 2011 | 05:24 PM
SaintGT2's Avatar
Does it measure individual knock? If it does then great.
Old Jun 10, 2011 | 06:11 PM
emadelta86's Avatar
Yup, individual knock voltage and individual ignition retard. Took the info from an old 3d. I have yet to use it..
XLR82XS
Oct 5, 2015 07:02 AM
Tiago
Sep 14, 2015 10:06 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
