DRSCCA Autox in 996tt
Old Jun 2, 2011 | 07:49 AM
ra996tt's Avatar
ra996tt is infamous around these parts
Originally Posted by VAGscum
I would upgrade three things if you are getting 2nd gear popout. Motor mounts, tranny mounts and the g- box detent mod. While you are in their changing the tranny fluid will get rid of any metal shavings that may be floating in there. The mounts will atop drivetrain movement that can sometimes contribute to gear engagement issues. Just my $.02
Thanks a lot. I didn't even think about the mounts. Are they hard to replace? I'm a DIY kind of person. I will be putting in the gbox detent when it gets here using a friend's lift. As well as straight pipes. Does the motor need to be dropped for the mounts? Thanks
Old Jun 3, 2011 | 08:07 AM
ra996tt's Avatar
I am also having the bolts that hold the metal brace by the rear tires come loose a few times in the past couple weeks. Do you guys think the tranny/motor mount is shot?
Terminator
Oct 7, 2015 08:12 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
gjpearce
Sep 30, 2015 04:26 AM
Fullthrottleguy
Sep 28, 2015 03:19 PM
