Kw v3 installed but.....
Old Jun 13, 2011 | 08:53 AM
JFC's Avatar
JFC
JFC is infamous around these parts
Raise the rear tdy and now the rear got the "rattle" or "knocking" on bumpy road not continous but randomly. SOOoooooo HECTIC~~~
some say to check on my swaybar links tightened enuf? and some say chk transmission mount.
helP~
Old Jun 13, 2011 | 11:33 AM
pwdrhound's Avatar
Originally Posted by jspporsche
Check sway bar end links. Get the car corner balanced. You want to do your best to use ride height to have the weight of the car sit evenly on all the tires. You probably won't get 50/50 but with that tire gap info, you have too much weight on the rear of the car. While this will help rear wheel traction, it really compromises the ability of the car to get weight over the front tires on braking and your stopping distances will go way up along with brake wear and heat.
Jim
You will never achieve 50/50 balance on a 996tt unless you put around 700 lbs in the trunk. The goal of corner balancing is to get LF+RR = RF+LR. Porsche specs the max difference at 20kg.
Old Jun 13, 2011 | 12:46 PM
jspporsche's Avatar
jspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond repute
Exactly. But imagine how bad it is with the nose jacked up in the air. Corner balancing cures a lot of ills. Most of which can't be discovered with a tape measure on a very stiff suspension.
Jim
Old Nov 14, 2011 | 12:29 AM
Kevganzon's Avatar
Kevganzon is infamous around these parts
Originally Posted by JFC
Finally got it fixed ....may i know what height you guys using? my front is around 2 fingers from fender to tire...rear less then half a finger.
I am getting some knocking sound when going through some rough road.
So you got it fixed. What did you find the problem was? im getting the same problem only when steering at low speeds or making a U-turn.
Old Nov 14, 2011 | 10:32 AM
RxPorsche's Avatar
RxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud of
Me too please let us know, Thanks.
audipwr1
Sep 25, 2021 01:31 PM
MadWhip
Sep 3, 2015 02:04 PM
