cool carbon brake pads, anyone using them?
Old Jun 6, 2011 | 09:20 AM
mtesh73's Avatar
mtesh73 is infamous around these parts
any feedback would be appreciated i am about to switch to them front and rear. would love to hear some pros and cons. thanks in advance.
mike
Old Jun 6, 2011 | 11:06 AM
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
far superior bite than oem. i would recommend that you buy them for both front and rear as the bias is quite bad if you try oem in the rear.
they do not squeek and have slots for sensors!
at the track they hold up quite well but have a slight tendancy to overheat if pushed to the limits! i.e not me driving but my track rat friend behind the wheel.
i think they are the best street pad out there for the money! at the track some pfc's will supersede them!
As an FYI you really have to be driving the car TO THE LIMITS for them to overheat dont be scared by my statement.
Mike
Old Jun 6, 2011 | 11:19 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
but they will also fry your rotors after a few hard sessions, ask me how I know
Old Jun 6, 2011 | 09:57 PM
porka's Avatar
haha - yes my rotors were a little blue.. but there holding up fine!
Old Jun 7, 2011 | 12:04 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Just make sure to break them in correctly and prep your rotors if possible. I fried CC pads and OEM rotors this way.
Back on new OEM rotors and CC all around. Great pads!
Old Jun 7, 2011 | 09:51 AM
ogomez79's Avatar
ogomez79 is infamous around these parts
There aren't many 'street' pads suited to hard track use, I've given up on trying to find a dual purpose setup and just swap out for track days. Then you don't have to compromise on either.
Old Jun 7, 2011 | 10:14 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I'm running Pagid yellow front and OEM rear. I have no complain on this setup; little noise but not enough to bought me.
Old Jun 7, 2011 | 04:29 PM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
they are great for the street.
However - as others have mentioned, if you track, you'll run through them, quickly.
I put a new set on for willow big and was getting the brake pad sensor light AND brake fluid warning after ONE lap! - However, everything felt fine so I was able to get 14 more lasp on that session...came in with the brake sens and the brake light illuminated.
Once things cooled down the warnings went away (btw did not boil the fluid - i checked).
Pads still have 30% on them after another month of street driving.
I'm going pagid next - you get what you pay for....
Old Jun 7, 2011 | 06:00 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
That is what happens when you are going 140MPH+ and braking down to 75-80MPH with a car and driver at 3700 lbs+
Go with the Yellow in front and Black for the rear.
Hope to see you at the Streets on 6/18 with the POC.
Old Jun 10, 2011 | 01:26 PM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
I've heard many opinions about breaking in new pads.
Anyone really know for sure what the proper way is?
Old Jun 10, 2011 | 01:36 PM
2muchtime's Avatar
http://www.stoptech.com/tech_info/wp...contents.shtml
here's some good info from Stoptech
Old Jun 10, 2011 | 02:57 PM
Thats good info, but it still says "theory" at the top of the page.
If bedding in is so important, why is it that they never advise on this when you buy a new hi performance car, or when you get your pads changes at the local pad shop?
What happens if you don't do any of the bedding in stuff and just drive off and use the car as you normally would?
Old Jun 11, 2011 | 08:01 AM
landjet's Avatar
Not much of a problem for street pads but track pads need to get some transfer residue on the rotors to be fully effective.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
