Is 01-02 engine harness the same??
Old Jun 7, 2011 | 04:31 PM
hasauto's Avatar
hasauto is infamous around these parts
Does anyone know if a 2001 TT has the exact same engine harness as 02??
To make a long story short I blew my engine on my 02 so I dropped in a complete 01 powerplant with harness and all... and now the engine starts but wont rev up over 1200rpm or hold idle,,, but I dont get any codes when I scan it.. So I want to know if the motor I put in it is crap or its just an electrical problem??
thanks
Old Jun 7, 2011 | 07:21 PM
Tim941NYC's Avatar
I all ways put the harness of the car on the new motor to remove the possibility of this very problem. My experience is it is by vin#. Do you know the vin of the car it came out of? If so call the dealer and see if the engine harness is the same part # for your car and the car the motor came out of. If you have the old harness out of your car trace the wires to the components. The crank pickup wires have the shielding, injectors will be bundled up same with coils. Then see if the round plugs pin out the same. Best I can do for you. I know pulling the motor back out is the last thing you want to do but you may just have to. Good luck.
Old Jun 8, 2011 | 06:10 PM
hasauto's Avatar
founds the problem.. When I put in the aluminum flywheel. I didnt line up the teeth to DTC so the timming was off... Opps
live and learn!!!
Old Jun 8, 2011 | 07:51 PM
Tim941NYC's Avatar
How did you manage that one? All the bolts will not fit unless it is indexed the right way. How did you get around the locating pin?
Old Jun 8, 2011 | 07:55 PM
hasauto's Avatar
Aftermarket 3 piece aluminum flywheel.... oppps
Old Jun 9, 2011 | 04:12 PM
ogomez79's Avatar
ogomez79 is infamous around these parts
Im confused on how thats possible as well?
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
ASLAN
Oct 8, 2015 08:58 PM
k-lo
Cayenne 958
Sep 1, 2015 04:51 AM
