Battery/generator light on... new battery 6mo ago, no problem starting/running...?
Old Jun 13, 2011 | 05:50 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
No codes on Durametric, but I can't find anywhere in Durametric to scan electrical system, ..Help?
Old Jun 13, 2011 | 06:10 AM
jspporsche's Avatar
jspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond repute
Could be the voltage regulator or a marginal charge rate.
My suggestion is a FREE charging system test including load test at Pep Boys or most any parts store that sells batteries.
Jim
Old Jun 13, 2011 | 06:26 AM
deckman's Avatar
Put a voltage meter on the battery and see if it's holding its charge with the engine running under a load, like with the lights and AC on. If not it's likely something wrong with the alternator. It's indicated by a steady lowering of voltage output.
Those test systems at auto parts stores won't always pick up on a faulty regulator. I took my bad alternator there and it passed the test. Yours could be a bad regulator but you don't really know and won't unless you replace it and reinstall the entire unit to see if it works. Kind of a PITA.
Old Jun 13, 2011 | 09:25 AM
landjet's Avatar
Good luck finding this Doc, at least you didn't have any CEL's after the recent upgrades.
Old Jun 14, 2011 | 04:43 AM
drhenrock's Avatar
Exactly,
Could be worse, dont' think this is from upgrades...knock on wood!
DetomasoGTS74
Nov 11, 2015 09:01 AM
GSR Autosport
Aug 26, 2015 05:20 PM
DSCOFF
Aug 23, 2015 01:22 PM
Phoenix604
Aug 19, 2015 10:39 PM
