stronger bulbs in rear indicators ??
Old Apr 10, 2005 | 03:02 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Every since I got the nite shades out on my rear indicators, they are not so bright for other road users, can I put in stronger bulbs without fusing anything out and if so and exact voltage recommnedations etc ?
Old Apr 10, 2005 | 09:20 AM
WARDHOG's Avatar
WARDHOG is infamous around these parts
What are night shades? Might consider changing the sockets for H3 bulbs to so can put in 55W Halogen bulbs. Now if you do that, or the resistor thing you mentioned, you might have lighting problems because you have disrupted the normal current flow by changing it. I.E.. when you hit the brakes, your front parking lights light up or you use the turn signals and your high beams come on. The reason is because current seeks the lowest path of resistance and those changes will alter the path and direct power thru the other lights.
Old Apr 10, 2005 | 10:35 AM
StephenTi's Avatar
StephenTi is infamous around these parts
Do they make a bright-enough LED light replacement for our cars? It'd be nice, considering most higher-end cars run LED's... the instant on/off effect looks much more higher-end.
Old Apr 10, 2005 | 11:17 AM
KJM3's Avatar
KJM3 is infamous around these parts
Polarg makes brighter than stock Orange bulbs which would work for you. You can find them at most "import" car shops.
LED's MAY work, but they may make your computer think that there is no bulb in the socket.
- KJ
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
vchris
Cayenne 955/957
Aug 25, 2015 05:37 AM
metzkaro
Aug 24, 2015 02:59 PM
ModBargains
Aug 20, 2015 12:28 PM
Jeff1smith
Aug 19, 2015 09:41 PM
