Should I have spacers at the front?
Thanks, one more pic and planning to have 10mm in this weekend...
You should use at least a 15mm spacer for the front.
I haven't seen a 10mm spacer for Porsche, either 7mm or 15mm.
Are the spacer specific for Porsche universal fit for all rims? Thanks
I have 7mm, 9mm, 12mm, and 15mm spacers (so they do make other sizes); and use them depending on what wheels and tire sizes. Are you sure you have ET40 up front? It doesn't look 40 from the first pic. My et37 (no spacer) looks much more closer to the fenders than yours.
More than you ever wanted to know: https://www.6speedonline.com/forums/...nted-know.html
Car looks great! Go with 7mm rear and 15mm front and really pimp it! It won't rub if you roll the rears.
I'm running 12" et 45s rear with 15mm spacers and 9.5" fronts with 265s
Thanks guy, maybe I'm wrong, will have them double check while taking them off. But since I have lowered the car and have 1.5 degree camber at the front, will figure out how many should I put.
Besides, do you guys think H&R could apply on aftermarket rims? As I seen they made for stock rims on the hubcentric.
As long as they are 5x130 they will work. My 7mm and 15mm are H&R; but bought offbrand from Ebay for other sizes. They work equally well.
http://cgi.ebay.com/ebaymotors/12mm-...Q5fAccessories
nice looking car!
