E-test on 2 wheel drive dyno
Old Jun 19, 2011 | 02:31 PM
square head's Avatar
square head is infamous around these parts
Angry E-test on 2 wheel drive dyno
Gents,
Took my 996TT for government required e-test.
Directed both the tech and the manager twice that the vehicle is AWD and to perform two speed idele test with exhaust sniffer..
I return from lunch and see my car on the 2 wheel drive dyno in 3rd gear at ~30 mph. Only rear wheels are spinning. I'm not happy with - lost my temper.
Damage to front diff / viscous coupler / awd system? I'm told that they turned PSM off.
Thx!
Old Jun 19, 2011 | 03:22 PM
_gez_'s Avatar
_gez_ is infamous around these parts
Quite possibly. This link is from an old thread. Why not show it to the test station and ask them if they now understand why you lost your temper.
http://blog.titanmotorsports.com/?p=293
Old Jun 20, 2011 | 12:21 PM
Anyone else? I'm sure most members have had their car smog tested...
Keep in mind this is a 3rd gear at 3000 rpm test, not WOT.
Perhaps I should refer to the owner's manual.
Thx!
Old Jun 20, 2011 | 12:33 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Here in california they do not set the cars on a dyno-only rev the car in neutral. They do have spot check points sometimes where they have a 2wd dyno, but AWD cars are waived for obvious reasons. I would get the car checked and if any damage - hand them the bill. PSM means nothing - at least 5% of the power was going to that differential which was fixed in place.
Old Jun 20, 2011 | 12:39 PM
sounds like you'll be getting a new front diff from them. it doesnt matter if they turned PSM off or left it on. wow this is unacceptable.
#TeamAIM
Old Jun 20, 2011 | 01:12 PM
Tj Hunter's Avatar
Tj Hunter is infamous around these parts
WOW...subscribed, I love how government mandates that we do this or that, but they CAN NOT GET A COMPETENT PERSON TO DO THE Fing WORK!!! Especially since you told them 2 times that it is an AWD car, you CAN NOT USE IT ON A 2wd DYNO!!!
op - make SURE you bring it to Porsche and have them check EVERYTHING that is associated with testing the front diff, then send that shop the bill!
Old Jun 20, 2011 | 01:40 PM
Centauro97's Avatar
Centauro97 is a jewel in the roughCentauro97 is a jewel in the roughCentauro97 is a jewel in the roughCentauro97 is a jewel in the rough
I'd document the FACTS:
1. The station has ONLY a 2WD dyno.
2. They completed a dyno test on the car.
What you told them is moot, they'll just say otherwise.
It is their obligation to determine the configuation of the car. They have access to the VIN, they can put it in the system and get a go/no-go for a 2WD dyno. If they don't have such as system, I'd argue that they're negligent.
Stupidity equals negligence and negligence is compensable if you have damages. Since it didn't explode on the dyno proving damages is the difficult part. It would be interesting to hear what a Porsche mechanic thinks about this. Excessive wear? Early failure?
Old Jun 20, 2011 | 04:04 PM
pwdrhound's Avatar
I live in Denver and here they use 4 wheel dynos for the smog test on all the 4wd or awd cars. I have a Audi quattro and a Lexus SUV and both of those were run on the dyno with a sniffer in the pipe. When I brought my 996tt to them to do emmisions they told me that in Denver they no longer put these cars on a dyno because they have fried several front differentials and had to pay to get them replaced. They now do just a stationary idle test which was just a sniff test of the tailpipe while that car sat there at idle. There are only a handful of awd sports cars including the 996/997 awd cars that are exclude from the dyno test...
My bet is that these guys owe you a new Porsche differential......Good luck...
Old Jun 20, 2011 | 06:00 PM
The challenge is this... There is nothing to inspect as everything is internal. My mechanic suggested swapping the fluid out to check for metal bits. I'm documenting the case now and serving them tomorrow.
Old Jun 20, 2011 | 06:19 PM
biobanker's Avatar
biobanker is infamous around these parts
See if the dealer will go after the testing center. They're qualified to say that there is probable damage, and they may have been through this before. Perhaps they can invoice the center for an inspection and then for whatever is damaged inside there.
You may be able to cut yourself out of the billing process if you're not the middle man.
Old Jun 21, 2011 | 02:03 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Test only shops in Cali seem to get it with AWD cars, but to be safe I remind them and have it put its AWD on the sales reciept before the test and watch them test it. So for no problems. Tested at 10% of maximum in all catagories. Very nice Vietnamese couple own the shop and there are always a few exotics there waiting to get tested so they must get it. The wife is really funny. She hands you your smog certificate likes it's your college degree.
Old Aug 9, 2011 | 04:12 PM
All underbody shrouding was removed. Everything was visually inspected. All fluids swapped. Fluid completely clean (like new). No damage. It's all I could do!
Old Aug 9, 2011 | 04:19 PM
GT3 Chuck's Avatar
Administrator
glad there was no damage...there is one more thing you can do...next time take it somewhere else
Old Aug 9, 2011 | 11:05 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
This is a slam dunk for a litigation lawyer if you have proof they actually did run it (like a test result sheet with the information, photos, other). The lawyer will take it happily, win the case or get a nice settlement for the damage done to the car even if it doesn't break today it's likely to break soon, possible leaving you stranded in a dangerous situation.
Lawyer up and see this one go your way.
Old Aug 10, 2011 | 11:52 AM
And996tt's Avatar
And996tt has a spectacular aura aboutAnd996tt has a spectacular aura about
This wouldn't have damaged the front diff or crownwheel and pinion as not enough torque will have been transmitted in the above test.checking the diff fluid will tell you nothing.
What it will have done is given the viscous coupling a very hard time.The viscous coupling is located in the rear part of the front diff housing.It is a sealed unit and has its own special fluid inside.Its job is to transmit drive to the front diff,it does this via plates that are surrounded by the special fluid. If the front wheels are prevented from spinning as in your case the fluid will heat up very rapidly as the energy fed in is turned to heat,if this happens for too long the fluid and plates will be damaged resulting in the coupling not being able to transmit the correct amount of power to the front.
If this has happened you probably wouldn't notice if you don't drive the car that hard ,but the symptoms would be the car wheelspins more in the wet and feels like it wants to go sideway more easily. This is because you will have lost some of the drive to the front, you might even be completely rear wheel drive.
Porsche have a test they can do to make sure the coupling is working as it should,they put the car on rollers and drive the rear wheels at a slow speed of 3 or 5 mph (slow enough to make sure the coupling doesn't get too hot)and then measure the force at the front wheels. They compare the results to a graph to make sure it is correct.
This is the only way to be certain no damage has been done
Hope this is not too confusing
