Who makes fender intakes?
Todd K will tune. You can either get the kit from Mark, or Todd (why not Mark.....and his fab work is a bit prettier).
Have Steve Ott at drivers Source do the install and remote tune w/ Todd K.
I have the full enchilada set up and you will get years of bulletproof enjoyment (unless you are like so many here who change their cars like shorts).
I make over 600 on pump and the car never breaks down.
Does Steve Ott do all your work?
Bad107 did you go ahead with this setup? Todd seems confident with mafless tune on tips also...
fender intakes going to be the only route to go bigger...tranny's too big for all that piping so might as well delete the stock intake/inlet pipes and go fender cone intake
Actually his car was converted several years ago to a maffless as Softronic has offered this for all Porsche cars since 2011.
Best,
Scott
Softronic - Porsche Performance Software Tuning
Faster than a speeding bullet.
Cayman | Boxster | 911 | Cayenne
Like us on Facebook for updates and promos
24HRS Daytona Winner programmed by Softronic!
Porsche Interseries programmed along with teamed owned Tudor and World Challenge cars in an exclusive with Softronic.
Porsche PCA racing binary check by Softronic for compliance.
Back from the dead.
Wait wait wait. Why CANT you run just the inlet pipe off the turbo with a MAF?
Because there are 2 turbos and only 1 MAF; so if you are running a MAF off of a fender intake inlet on one turbo, you are only metering half of the airflow and the car would not get the correct readings.
Are they restrictive?
Whats Todds username on here is he still active?
Si
I would think he could make it a little less restrictive with a more gradual transition but it's got to be a ton better than the stock setup for sure! He really does seem to be doing terrific things with his 3D printer though! An off the shelf fender inlet at a reasonable price would be pretty sweet, I hope he or someone else puts them into production.
Looks awesome. Will never buy it at any price close to that.
