Check Engine Light
Old Jul 7, 2011 | 07:51 PM
landcruiser's Avatar
landcruiser is infamous around these parts
Check Engine Light
I noticed that my 2002 911tt was idaling a bit high today. When I pulled into the garage, the check engine light turned on. Problem, is I am about 180 from the dealership.. Should I tow it to get it checked?
Old Jul 7, 2011 | 08:02 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Before paying for a near 200 mile tow, I would get my hands on a durametric and read the codes, might be something that you can drive through. If you are 180 miles from your shop/dealer, the cable will pay for itself by avoiding 1 unnecessary tow. Good luck, keep us posted.
Old Jul 7, 2011 | 08:06 PM
There is a local shop that works on German cars. He probably at least has one of the code readers, Right?
Old Jul 7, 2011 | 08:08 PM
kwei's Avatar
Very likely, even the code scanners Auto Zone lends out will read the codes for you, I am just assuming you dont have one of those near you either, you are in the middle of area-51, correct?
Old Jul 7, 2011 | 08:15 PM
I'm in a small town. Plenty of auto-zones. Just not in a place where I would trust anyone to work on a 996 TT. Should I just run by auto zone?
Old Jul 7, 2011 | 08:21 PM
kwei's Avatar
I would, if it's not too far. They will have you leave your drivers license most likely, I would drive a different car to pickup the reader.
Old Jul 7, 2011 | 09:08 PM
Got the scanner and received one code. P0507. Idle control system RPM High
Old Jul 7, 2011 | 09:12 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Old Jul 7, 2011 | 09:16 PM
kwei's Avatar
Originally Posted by NOLA911
I got my fingers crossed in hopes that your solution is the same as post #5.
Old Jul 7, 2011 | 09:34 PM
Checked the oil cap.. It was on tight. Car is still idaling a little high. Should I not risk driving it to the dealership ?
Old Jul 7, 2011 | 09:35 PM
kwei's Avatar
I would call a few people who know more than we do and see what they say. I would guess most will play it safe, but it might be something that you can drive with. Anyways, that is what I would do.
Old Jul 7, 2011 | 09:40 PM
I will call the dealership tommorrow and see what they recommend. Thanks for your help !
Old Jul 7, 2011 | 10:17 PM
kwei's Avatar
Keep us posted, no problem, hope its a simple fix.
Old Jul 8, 2011 | 07:57 AM
wross996TT's Avatar
As Lauren indicated in the Rennlist post:
Possible fault cause
♦ Throttle is jammed
♦ Leaks in intake air system
I would check for leaks. Driving the car should not be a problem...blinking CEL's are bad.
Old Jul 8, 2011 | 10:20 AM
Just spoke with my Porsche service advisor. He told me to clean the mass air flow meter and my H&K air filter. Does anyone have instructions on how to remove and clean properly ?
