check engine light , rough idle then dead. Help!
Old Jul 17, 2011 | 10:27 AM
porscheforfun's Avatar
porscheforfun is infamous around these parts
driving the car yesterday and had to get it towed.
Here are the facts of the whole deal.
Two days ago installed Speedtech exhaust I touched the O2 sensors and wiped them off because I saw some white residue on them . I wiped with my bare hands. Not sure if this was a wrong move to start with. Installed the exhaust and the 2 sensors on each side . To tell you the truth I also think I switch the sensors when I put them back on.
Check engine light came on first but car drove fine. Drove the car for about 30 miles and then started sputtering, then would no go kinda like in limp mode.
made it to the fwy exit and died. I was already pulling over so now being on the side of the road , I put it back in park started it rough idle and died. Called AAA
and now it sits in my drive way . Would the O2 sensors putting them on in the wrong spot cause all this havic? I hope thats all it is . I havnt read the code yet to see what it says . This just happened last night . Any advice would help Thanks !
Old Jul 17, 2011 | 03:24 PM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
You need to get the codes read out and post them first. WE could all be guessing unless you give us an area to think about.
Do you have access to a Durametric?
Old Jul 17, 2011 | 07:55 PM
Update : Codes reading PO153 and PO134
first one says o2 sensor circuit slow response bank 2 sensor
PO134 says o2 sensor circuit no acitivity detected Bank 1 sensor 1
Old Jul 17, 2011 | 08:49 PM
you probably switched them.... the grey wire should be furthest away from the turbos... the black wire o2 should closest to turbos... did you plug them in on top? did you disconnect them when screwing them in or did you just bind the wires as you screwed them into the exhaust? you could have damaged the o2s....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 17, 2011 | 09:38 PM
I agree i think i switch them would this cause the vehicle not to turn over ? Once fixed would it start or is there some kind of reset . Right now it wont start
Old Jul 18, 2011 | 12:53 AM
"the vehicle not to turn over"
Do you mean the engine does not even try to rotate when you turn the key, or do you mean the engine spins over but wont start
Old Jul 18, 2011 | 08:15 AM
Yes, I plugged them in on top . Did not disconnect when screwing these back in , just twisted the wires . I am going to switch it back hopefully the o2 is still ok . But right now it wont start. It acts like it wants to but it wont idle it will die right away if it starts.
Old Jul 18, 2011 | 08:18 AM
The engine rotates but when it starts it dyes right away it will idle for about a 1-2 secs. I havent switched the wires back yet I think the O2 sensor wires are backwards , but I find it hard to believe that this would not allow the engine to start , maybe there is a limp mode? I cleared the error code .
Old Jul 18, 2011 | 09:03 AM
jspporsche's Avatar
jspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond repute
If you are just going to fight correct repair info then why do you ask for help? You have one known problem and until you fix it, why keep asking questions? Plus if you just let the lead wires twist, they are likely toast too.
Fix what you know is wrong and THEN lets see what else happens.
Jim
Old Jul 18, 2011 | 09:44 AM
Jim,
No disrespect to you or your answer. Im just trying to solve whats wrong. I know you guys have a lot knowledge and Im just trying to avoid the dealer . This is not a daily driver just a toy car. I will switch the sensors and see what happens .
Old Jul 18, 2011 | 05:04 PM
Reconnect o2 sensors correctly still wont start acts like it wants to but idles for one second then dies
Old Jul 19, 2011 | 12:55 AM
Fuel pressure, get the pressure checked, you know you have a spark as it kick over, sounds like the fuel pump pipe could be split. At least you will know if you have it checked out.
BTW you car will idle without cats fitted. I had mine running on stands for over 30 minutes without an exhaust after some major work having been done to the engine. Eventually the Cell came on but it still ran and started .
If your car wont start at all, I'm not sure it is directly related to cats, as when the car is cold it starts in open loop anyway. perhaps you have damaged the DME with those crossed wires, but I wouldn't know anything at all about that.
To rule out pump issues and pump relays I would start with fuel pressure testing.
Old Jul 19, 2011 | 09:49 AM
thanks sunnyside ,
taking to dealer this morning to get it checked out . I am the second owner and the original owner has taken to the dealer religiously so I figured if I ever sell the car it would be a nice track record that its always been dealer maintained .
Old Jul 19, 2011 | 04:24 PM
Fuel sending unit went bad , basically like a dumb as$#$ ran out of fuel
Old Jul 19, 2011 | 04:28 PM
Well at least your honest enough to tell us all. Nice one and at least you have the fault fixed.
