3rd brake light removal
Old Jul 24, 2011 | 02:55 PM
andymac's Avatar
andymac is infamous around these parts
About to dismantle my standard decklid and fit the gt2 version.
So I don't break it , how do you remove the 3rd brake light ?
Also do the rubber bungs on the corners of the original decklid just unscrew ?
Old Jul 24, 2011 | 03:21 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
For a moment, I thought this was similar to a rear wiper thread . Post some pictures when you get the GT2 deck lid installed. Sounds like it's a cool mod.
Old Jul 24, 2011 | 03:37 PM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
You can find that in the owners manual.
Old Aug 11, 2011 | 02:21 AM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
Doesn't it mean GT2 and original TT bootlid sharing the same 3rd brake light?
Old Aug 11, 2011 | 03:12 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
it is the same 3.brake light...
Old Aug 11, 2011 | 06:03 AM
boyg's Avatar
Thanks.
Old Aug 11, 2011 | 04:31 PM
landjet's Avatar
The rubber gasket around mine is breaking up so need to take it out. Would also like to hear how.
Old Aug 11, 2011 | 05:28 PM
XLR82XS's Avatar
Remove the plastic end tab. There is a slot - insert a small screwdriver into slot and turn it a 1/4 turn. (forgot which way) Gently pry the lens out and unplug the pigtail connection. Install is the reverse.
Old Mar 26, 2015 | 01:43 PM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
Have you actually done this successfully? I see the place where the screw driver goes into but I am afraid to crack the lens as I twist. It does NOT want to move.
Old Mar 26, 2015 | 03:40 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
I've done it and it was simple. No lens cracking and no problems. Maybe soak your screw for a while before trying to turn.
Old Mar 26, 2015 | 03:41 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Yup. Just did this. Pop the end cover off and then rotate the inner piece with a screw driver.
Old Mar 27, 2015 | 10:34 AM
contsaga's Avatar
contsaga has a spectacular aura aboutcontsaga has a spectacular aura aboutcontsaga has a spectacular aura about
OK, here's some pix
I messed up my rubber trim also, when I was installing the AeroKit loom for a fix spoiler solution to eliminate Spoiler Malfunction Light...
then, figured out that I goofed by taking the light out from under the lid...
It's in the owner's manual, like someone said.
ID:	417154   Click image for larger version
ID:	417155   Click image for larger version
ID:	417156   Click image for larger version
Old Mar 27, 2015 | 10:57 AM
jpflip's Avatar
That's useful! Thanks for sharing!
Old Mar 28, 2015 | 02:59 AM
Thanks very much for the photos. That is very good to know. It appears that the whole piece has to be replaced as I cannot get to the bulbs.
Old Mar 28, 2015 | 09:58 AM
contsaga's Avatar
The whole light cost $106, so it's not cheap just to replace a bulb or the rubber trim...
However, the bulb is replaceable...
See attached...the bulb is #5 in the list, cost is $1.44
