997 SSK installed!
Old May 21, 2015 | 02:53 PM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Originally Posted by daytrip00
I installed one in mine too. I love it as well. Shifting is crisp and tight. Total no brainer mod for less than $200.
I thought the OEM 997 SSK is ~$450? Or are you talking about an aftermarket kit?
Old May 22, 2015 | 07:54 AM
it is about 450$ new. used they go for 350$. i actually have used oem 997ssk kit if anyone wants it pm me.
#TeamAIM
Old May 22, 2015 | 01:38 PM
'02996ttx50's Avatar
pd 100 for mine. got lucky as i sometimes get first shot at parts lying around a pcar shop
Old May 22, 2015 | 02:24 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
How much? I'm interested
Old May 24, 2015 | 10:30 PM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
I got one for 350 as well if anyone wants it.
Old May 25, 2015 | 04:35 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
Just out of curiosity: has anyone ever compared the 997 SSK internals to a B&M? Are the lever ratios different?
What makes the 997 SSK better? Is it a stiffer cage?
Old May 25, 2015 | 09:14 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
the 997ssk and all other porsche shifters come ina cage with alignment clip.
B&m is just a shaft you install into your stock shifter cage last i checked.
Old May 25, 2015 | 09:23 AM
pwdrhound's Avatar
Yes. I had a B&M prior to the 997SSK. The B&M was utter garbage in comparison. I would not waste money on it. I can't recall what the ratios were as I removed the B&M from the car right away. The OEM 997SSK is a very nice shifter and much better than the B&M on all fronts. Just plain works well. I ended up selling the OEM 997SSK for $350. It sold in about 2 hours...
Old May 25, 2015 | 11:11 AM
06Turbo's Avatar
06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future
I'm sure you have answered this before, but how does the (996?or 997?)gt3 cup shifter compare to the 997ssk.?
Old May 25, 2015 | 11:40 AM
pwdrhound's Avatar
The factory 996Cup shifter is a race part and as such uses metal bushings on all the critical load bearing areas. That gives it very much a "rifle bolt" feel to it especially when combined with the thick all metal cup cables. I feel that is the ultimate set up for these cars. The Cup shifter has longer throws than the 997SSK. All the GT3/2 shifters (996/997) will have slightly longer throws than the 997SSK as they are designed to be used in conjunction with the shorter non-counter weighed gearbox selector lever that comes on all GT2/3/cup gearboxes. The shorter lever can be retrofitted onto the TT gearbox.
Old May 25, 2015 | 12:55 PM
BLKMGK's Avatar
Numeric is also an option. Stainless steel sealed bearings everywhere and an aluminum CNC body. Not a difficult install. They sell cables as well if you want to further remove slop from the shifting but I felt no need to do so after installing mine. Shift ratio is adjustable though if you go for the shortest you must trim a bit of carpet under the shifter so allow for the throw. No complaints with mine at all but it's not cheap.
Mackchacha
Jul 9, 2019 11:03 AM
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
