Hooked up battery backwards
Old Aug 30, 2011 | 08:52 PM
cab2u's Avatar
cab2u is infamous around these parts
Ok. I had one of those incredibly stupid moments that has been haunting me all night. My battery died. I got a new one, put it in the car, backwards, attached the cables. I still can't believe I did that. Smoke came out from the engine, while making a high pitched whine. Possibly the fan? Dont know
When i realized what I did, i fixed it. Car started right up but Now I have the generator battery warning and voltage less than 12. And the radio is dead.
What a freakin idiot I am. I am good for one of these once in a while.
How badly could I have damaged the car? Everything else seems to be working.
Old Aug 30, 2011 | 09:08 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I would probably check your fuses, all of them ..
Old Aug 30, 2011 | 09:13 PM
tnoice's Avatar
tnoice is infamous around these parts
Also check your alternator. That could be what you burned up in the engine area. As the engine is running, your meter should read around 13.3 volts and at 3,ooo rpms or so it should read around 14 volts. If it is not, you probably burned up the alternator.
Old Aug 31, 2011 | 12:14 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Most likely the regulator on the alternator. If it's only that and the stereo, you got lucky. Are the remote lock, cooling fans, windows acting normal?
Old Aug 31, 2011 | 05:02 AM
cab2u's Avatar
Remote seems to be fine. Auto window didnt work but I reset them and they are ok. Don't know about the fans.
I night dropped it off at the dealer last night. I didn't tell them in my note what I did. Quite embrassing. Realized during my crappy night sleep that i need to tell them. Worried they will want to fix or charge me more than needed.
Did I say I'm an idiot? Was in a tremendous rush. Car was in the street in the middle of a busy town Not paying attention. Ugh.
Old Aug 31, 2011 | 08:56 AM
tarzancoe's Avatar
tarzancoe is infamous around these parts
Don't sweat it. Car will be fine. And, you will never do it again right?
Old Aug 31, 2011 | 09:31 AM
porscheforfun's Avatar
porscheforfun is infamous around these parts
Make sure that you had at least 3/4 of a tank in the car. It will register your fuel sending unit if you did with less it will cause havoc on the fuel sending unit . It will not register correctly , at least thats what I experienced.
Old Aug 31, 2011 | 09:34 AM
cab2u's Avatar
Thanks. Car needs a new alternator. If I said how much Porsche is charging me, i have no choice. At least double what an Independant would charge. This is why they say measure twice cut once. Never do something in a rush. Even easy things.
Old Aug 31, 2011 | 01:52 PM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Why not tell the stealership thanks for the diagnosis and do it yourself? $400 bucks
Old Aug 31, 2011 | 03:40 PM
cab2u's Avatar
Although I am very handy (insert joke here), I have never done engine work like that. I would have considered taking it to an independant but the nearest one would be very far, and i could not take the chance of having the car die on the way. I am so annoyed at what I did, I just want it fixed so I can make believe it never happened.
Old Aug 31, 2011 | 04:02 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
That reminds me of the time that I personally bled the brakes of my Morris Cooper S. Bloody car had to be flatbedded to the shop. That was the last time that I did anything more than pumping the tires.
Old Aug 31, 2011 | 05:39 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
Originally Posted by cab2u
Car needs a new alternator. ... This is why they say measure twice cut once.
I once measured once and cut twice (fortunately it was only a curtain rod ). Glad that it's "just" an alternator. Hope you're back to enjoying your car soon!
Old Aug 31, 2011 | 08:56 PM
richgraham's Avatar
richgraham is a jewel in the roughrichgraham is a jewel in the roughrichgraham is a jewel in the rough
The expression "buying experience" rings true here. Ca-ching! You just forked out for some.... Could'a been worse....
Old Sep 1, 2011 | 02:26 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
Compukidd
Sep 30, 2015 11:03 AM
UrsaMinor1
Sep 26, 2015 01:23 AM
