Tech Question
Old Jul 16, 2003 | 08:43 AM
Duane's Avatar
Duane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud of
Tech Question
My battery went dead. When I jump started it the PSM,Airbag failure and check engine light are staying on. I know the PSM and airbag lights come on but I am not sure about the check engine light. Can someone please advise.
Old Jul 16, 2003 | 06:20 PM
MacedoMS's Avatar
MacedoMS is infamous around these parts
You didn't accidently cross the terminals when you jump started the car? If not, sometimes the low voltage input will set a code if the battery is in a weak state of charge and you try to start the car. Any idea what the codes may be, Duane?
Old Jul 16, 2003 | 07:15 PM
PorschePhd's Avatar
Duane,
Run to AutoZone and have them pull the code for you. Yes they can do it. It will have a generic OBDII code. Call me with it and I can tell you what it is. You can also have them clear it for nothing.
cnebrask
Oct 3, 2024 08:19 PM
ThunderRolls
Sep 13, 2015 10:41 AM
docboy
Sep 6, 2015 06:57 AM
991carreradriver
Aug 30, 2015 04:16 PM
