Heatsoak?? 60-130
Old Sep 6, 2011 | 11:48 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
Heatsoak?? 60-130
I was gonna go try some 60-130 runs.
Lets say I did 2 runs back to back. Would my 3rd and 4th run be a lot slower due to heat soaking?
intake/exhaust/ecu flash are my mods. Stock intercoolers.
Old Sep 7, 2011 | 12:49 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Depends to some extent on the outside temperature. Is it still above freezing in Calgary?
The best way to find out, and a good idea in general, is to log data with a Durametric for all the runs. One of the variables that you can record is inlet air temperature. This will give you a good indication of how effective your intercoolers are with your current mods.
Old Sep 7, 2011 | 02:19 AM
ek9max's Avatar
Ya it's well above freezing. I'd be doing the runs at about 15 degrees Celsius.
Old Sep 7, 2011 | 05:14 PM
ttboost's Avatar
You will get some heat soak and from experience, my guess is your runs will get slower by a couple tenths at a time. When I added 100% meth, my runs were within a tenth even after 4 or 5 runs in the muggy New England heat.
Bobbyfali
Jul 31, 2017 01:28 AM
Fadi
Oct 5, 2015 12:14 AM
keithta
Nov 7, 2008 02:15 AM
Mr Kram
Dec 24, 2005 01:12 PM
