911tuning vs Europipe Loud
Old Sep 9, 2011 | 10:14 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Only mod where I never, ever second guess if it's worth the money. I enjoy every second of my 911Tuning exhaust. Would buy it again in a heartbeat.
Old Sep 9, 2011 | 12:01 PM
bbywu's Avatar
Originally Posted by unvmy996
mr Bob, with all due respect you dont need to be a rocket scientist to look at the two and tell right away which is less restrictive .
secondly ,i dont need numbers to tell me which is less restrictive, numbers are just numbers that can be made to whatever someone wants, i have NEVER seen the europipe make big boy numbers ,marks does on alot of cars not just one.
and lastly ,i have personaly seen the europipe CHOKE on high horsepower applications !!
We're having an adult conversation - I'm good with everything you are saying.
Restriction and back pressure is the same - whether or not it is high horsepower or not. The number does not change just because your boost pressure or air flow is greater, only it's influence on temperature as EGTs climb.
An exhaust's backpressure dictates the pressure ratio across the turbine - the turbine needs to be able to do the most amount of work possible with the available inlet pressure. This number is relatively constant....ie for a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. I think it is just as important to see the numbers behind back pressure, as it not only influences the HP and torque, but also on temperatures IATs and heat cycling with repeated use. A single run on a dynometer or a high velocity run is only part of the equation.
The reason for using a low restriction exhaust on a turbo application is to reduce the back pressure as much as possible - I don't think it is unreasonable to compare actual data...we do this for compressor maps for turbochargers, IATs for intercoolers, and unsprung weight for suspension components. I hope Marek doesn't take this as a bash against his fabrication or design...on the contrary, I had never been happier with the exhaust he made for me. I'm just a numbers kind of guy, and a dyno run is one component of the big picture.
Old Sep 9, 2011 | 01:19 PM
unvmy996's Avatar
Bob ,
im familiar with all of this and i know why we use a less restrictive exhaust on turbo applications, its basic stuff was one of the basic books i read many years ago i think by corky bell. but good info non the less.
i know you are a numbers type of guy , and thats fine. I still stand by my first post.
Old Sep 9, 2011 | 03:36 PM
WOODTSTER's Avatar
Originally Posted by Zippy
I have a custom EP XX Loud with 997 RSR cats and love it. That being said, If I was to buy a different exhaust, I wouldn't hesitate for a second to deal with Mark.
I concur. And I was a certifiable exhaust maniac. I had everything from Europipe, to Switzer and everything in between. I would suggest listening to one before purchasing. Markski will treat you right. Good luck.
Old Sep 9, 2011 | 04:00 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
the 911tuning muffler design vs europipe shows me enough.....europipe is heavy and dont look racing like...simple but the truth....if german tüv dont f... .me i would go with 911tuning exhaust
Old Sep 9, 2011 | 09:03 PM
Mattyrae's Avatar
Mattyrae is infamous around these parts
Ok, so when is the next sale or group buy special? . Markski?
Old Sep 9, 2011 | 09:25 PM
LOL
IM working on a demo that will have no more then 5 miles on it... If someone else will not snag it Ill keep you in mind...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 9, 2011 | 09:57 PM
Mattyrae's Avatar
Originally Posted by MARKSKI@911tuning
LOL
I am interested in the 3 inch X-pipe system with 100 cell cats. My GT2 should arrive next Tues. / Thurs., I am 99% sure it has stock exhaust, let me know.
Old Sep 10, 2011 | 01:27 PM
johnspeed's Avatar
Finally heard a Markski 3'' cat system system on a k24/18g car the other day. ...It sounded great....I picked my Milltek because I wanted to keep it toned down and gain more power then my old Cargraphics,,,BUT I think I might reconsider now having his system, even though it is bit louder.......lol.......
Old Sep 10, 2011 | 01:31 PM
raineycd's Avatar
He makes quieter ones for girls...
Old Sep 10, 2011 | 01:47 PM
johnspeed's Avatar
Right up my alley then ...I drove in stealth mode because I did not need to be a poser with sound and no driving thrills
XLR82XS's Avatar
Originally Posted by Nikolas
I would go with Markski's also. I have the Speedtech 3" which you should also check out. Amazing sound and similar weight savings to Markski's exhaust.
I have 3" Speedtech as well. Go cat-less.
Old Sep 10, 2011 | 01:48 PM
raineycd's Avatar
I rev on every honduh I see!
Old Sep 10, 2011 | 02:37 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
Has anyone here heard the switzer exhaust compared to markski's? just wondering how they differ in sound..which is louder and if one is more exotic sounding then the other.. thanks in advance
Old Sep 10, 2011 | 02:45 PM
Yes we had one. I liked it.
Just a different design.
