Engine hesitation or just my imagination?
Old Sep 12, 2011 | 01:10 PM
Sam996TTS's Avatar
Sam996TTS has a spectacular aura aboutSam996TTS has a spectacular aura aboutSam996TTS has a spectacular aura about
Rhyme not intended
Car: 2005 Turbo S Tip - all stock.
Symptoms: slight dip in the RPM (i.e. 50-100 RPM) and almost imperceptible loss of power for a split second when pressing on the accelerator, particularly when already in low RPM range (i.e. pulling out of a stop sign..). It's more perceptible if I'm actually trying to floor it because there is a 1/4 second of no reaction/no power.
Conditions: 40C outside temp, engine not fully warmed up (but warm enough).
I doubt a mechanic will notice it so before I go and make a fool out of myself, I want to check if this is a common problem.
Another issue, maybe related (?), sometimes the engine hesitates or stalls in the following scenarios:
  1. Engine cold, when putting gear selector from P to D sometimes RPM dips a little too much (~ 400-500) and struggles then recovers, or stalls.
  2. Engine not fully warmed up, at the moment the car stops at a stop sign after hard breaking (smooth breaking doesn't do it..)
Are these symptoms indicative of something specific?
Old Sep 12, 2011 | 02:13 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Most likely the Variocam actuator changing the cam- mine does it as well.
Old Sep 12, 2011 | 02:15 PM
Sam996TTS's Avatar
What part does yours do, all of the above? Is something that can be fixed?
Old Sep 12, 2011 | 02:25 PM
PAULUNM's Avatar
Mine is a hesitation at around 2k rpm- which I'm told is normal. There's a couple of threads over at Renntech that review this.
Your hesitation seems aweful low, have you had any codes read? I'd wonder about the MAF, coilpacks, and plugs...
Old Sep 12, 2011 | 03:36 PM
disconnect the harness from the MAF and see if it does the same thing
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Jul 29, 2019 11:13 AM
salesguy01
Mar 25, 2019 09:39 AM
Sales@RSW
Sep 3, 2015 09:34 AM
vr6tee
Aug 29, 2015 03:52 AM
rgreenberg
Aug 23, 2015 07:06 AM
