Advice on suspension settings
Old Sep 14, 2011 | 06:25 PM
TTS's Avatar
TTS
TTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of light
I have KW3 coilvers and adjustable H&R ARBs which are set to medium front and back. The front is lowered until the top of the tyre is almost at the level of the top wheel arch. I have noticed my low speed ride is quite stiff but at the track the car rolls a lot and also understeers when pushed.
Any of you guys can advise if I should change my ARB setting, increase my ride height at the front or change the rebound and/ or damper setting in order to correct this.
Many thanks!
Old Sep 14, 2011 | 07:28 PM
Basic's Avatar
Basic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant futureBasic has a brilliant future
Many thanks!
quick answer try stiffening the rear bar or softening the front (preferred)
what are the current settings on the shocks f/r rebound/compression?
what tires, sizes and tire pressures?
alignment settings?
Many things beyond coilovers and asb that could cause understeer
Jul 29, 2019 11:13 AM
Steven997TT
Aug 27, 2015 02:56 PM
ECS Tuning - VW
Aug 25, 2015 02:54 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 18, 2015 01:04 PM
