Boost Loss found????
Old Oct 4, 2011 | 09:58 AM
Remote's Avatar
Remote has a spectacular aura aboutRemote has a spectacular aura about
Hi all,
Yesterday i noticed the car was quite down on boost, , pushing out .6 - .8 in 2nd and third, i thought it felt slower but in the back of my head thought i might be fooling myself and it might just be the Boost gauge reading.
I booked the car in for Thursday but in the meantime had a route around and found that a small pipe connected to the front Diverter Valve had a tear in it.....
Straight after i got the remap the car was boosting 1.2 consistantly, however has gradually dropped a bit to where it was boosting 1-1.1 before yesterday....so im hoping this is the problem.
Would this rip cause a loss in Boost pressure AND what exactly is this pipe???
Thanks in advance.
Old Oct 4, 2011 | 10:00 AM
raineycd's Avatar
Yes it would! This is the hose going to the diverter valve (DV) to control the release of boost pressure.
Old Oct 4, 2011 | 10:24 AM
Remote's Avatar
Thanks, so if the hose is there to release boost, how would it cause boost loss?? Thanks for the info
Hopefully when its sorted il be back to 1.1/1.2
Old Oct 4, 2011 | 10:46 AM
raineycd's Avatar
Well, that hose is a pressure hose that pushes the diaphragm on the DV when the pressure becomes too great. Most likely, it was leaking causing lower boost and probably a higher surge when you let off because the DV would not be pushed as much.
Old Oct 4, 2011 | 12:06 PM
Remote's Avatar
That makes sense as it was surging when i let off the accelerator more thn usual......
Thanks alot bud
Old Oct 4, 2011 | 12:09 PM
raineycd's Avatar
Thanks alot bud
No problem - have them boost leak check it once they replace the hose! So many things that could leak - best have them check it while they are in there!
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
sparks
Sep 8, 2015 03:03 PM
WheelB
Sep 3, 2015 10:26 AM
