new rim/tire setup... need spacer?
Old Oct 7, 2011 | 10:54 PM
FlyingGuy's Avatar
FlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant future
im very wheel/tire ignorant, so i hope someone can help out. im just wondering if im going to be gaining or losing clearance, if i will need spacers, if i will rub...etc
I am on H&R springs
current-
Work Brombacher with Michelin PS2.
19x8.5 +51, and then a 7mm spacer. 235/35 tires
19x11 +45, and then a 14mm spacer. 305/30 tires
possible next purchase-
O.Z. Alleggerita (tires still unknown)
18x8.5 +53mm
18x12 +51mm
i understand that the tires will play a factor to some degree in rubbing issues. but lets say a 235 front and a 315 rear...
with just these numbers, what does that say about clearance? spacers needed? will i rub?
thanx in advance
Old Oct 8, 2011 | 10:14 AM
AutoTalent2's Avatar
AutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to all
Should not need spacers. It depends on the look that you are after as well
Old Oct 8, 2011 | 01:35 PM
ard's Avatar
ard
Cannot say for sure, but consider a 9" front rim- it will let you do 235/40 or 265/35-18 on the same rim...etiehr with a matching 315/30-18 rear.
Old Oct 8, 2011 | 06:17 PM
tphss's Avatar
tphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of light
May I ask why are you changing? Because I was actually thinking of getting a set of O.Z. Ultraleggera 19's.
From what I understand 315 is the maximum width in the back. Needs to be 30 profile in the back, so 315/30-18. Front 235/40-18.
Old Oct 8, 2011 | 07:36 PM
FlyingGuy's Avatar
the OZ rims i was looking at are either 8 or 8.5
its my daily driver. to work, to friends, to wherever. I was looking to go to an 18" for a bit more ride comfort, and something that could double as a light rim with sticky tires for occasional track rentals.
Boldgt
Mar 23, 2016 11:07 AM
djhill
Oct 29, 2015 07:04 PM
DYL 911
Oct 1, 2015 02:47 PM
Pcar991
Sep 29, 2015 05:20 AM
bshah1976
Sep 11, 2015 04:42 PM
