K16+mods results at 1/4 mile w/ datalogs for review
Old Oct 9, 2011 | 08:44 PM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Hi folks,
Went to an MIR rental Friday. Been like 5 years since I've actually driven so that was fun at first Had to remember what to do...
But anyway Track was around -260 DA and 60-70F.
Ran Sumitomo HTRIIIs at 32/40psi
Best run was 11.84@121.9 and another 11.85@122.3. I'll scan the slips somewhere if I remember where I put them. Best 60' was 1.78 an a couple 1.8Xs.
I datalogged a couple of the runs to see how she is doing IAT and Peak boost wise. (Attached below)
Car has some weight removal -- rear seats, gt3 console, lighter battery, no spare. But I'm ~290lbs so I figure they just about cancel out.
So real questions:
At 1.0BAR these seem like the car is making good power but I'm worried about the IDCs? A little over 100%.... AFRs around 11.5. Should I worry about anything? IATs good?
Next stop billetK16s and injectors!!
Henry
File Type: zip
Old Oct 9, 2011 | 11:44 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
That ET sounds about right for the mods you have, your probably making what 440-465awhp?
What exactly is IDC, i'm not familiar w/the nmenoic (sp)?
I meant to come to the rental and everything and then something came up at the last freakin min....arggggh!
Old Oct 10, 2011 | 07:53 AM
injector duty cycle. and yeah the OP should be concerned about that. his tune is fully maxing out the fueling on his car.
#TeamAIM
Old Oct 10, 2011 | 11:34 AM
vr4henry's Avatar
Yep.
So, I guess my real question is what do other K16s @1.0BAR look like? I imagine they're ~100 IDC as well. Is this as dangerous as my paranoid mind thinks?
Old Oct 10, 2011 | 11:36 AM
vr4henry's Avatar
I have no idea on the awhp. I've been meaning to dyno for a baseline and check AFRs (more data points than my durametric records)
Jimmy P. was saying you might show up. Next time!
Old Oct 10, 2011 | 11:43 AM
k-ore's Avatar
Ewww...100+% Injector duty cycle, Henry...your lucky you didn't detonate. Invest in some 1100 cc bosch or ID injectors so you have more then enough fuel, especially if you go w/E85.
Your times to me seem about right for your mods IMO, but i'm only a novice.
Old Oct 10, 2011 | 11:44 AM
k-ore's Avatar
I'm coming to the Nov rental w/o a doubt.
Jul 29, 2019 11:13 AM
alevine
Nov 4, 2015 10:05 AM
vbb
Aug 21, 2015 10:17 PM
