Finaly found pre-most ipod/mp3usb solution
Old Oct 11, 2011 | 10:17 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
I just bought this xcar link system which is a 15 minutes plug and play system for our Becker radios. Quality is excellent. You can connect usb, sd card and/or ipod. Link and some installed photos...
Here is the link to the type 5 model I have: http://www.xcarlink.co.uk/product.ph...4&cat=0&page=1
Old Oct 11, 2011 | 10:24 AM
Kapoosh1's Avatar
Kapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura about
Nice! I'll have to check this out.
Old Oct 11, 2011 | 10:44 AM
scottrx7tt's Avatar
scottrx7tt has a spectacular aura aboutscottrx7tt has a spectacular aura about
i just ordered one! hopefully it charges the ipod also??
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
I was curious on ipod charging as well
Old Oct 11, 2011 | 12:56 PM
Terminator's Avatar
Yes it charges all ipods and iphones. It is super smart. But you must get the ipod version. Mine isn't. In my version you can connect ipod via aux headphone jack input. I just thought usb key is a sufficient solution for me. My ipod is filled with 120Gigs and I thought ipod is overkill for my type of journeys.
Old Oct 11, 2011 | 12:57 PM
greekc6's Avatar
keep us posted on if it charges and ease of install please. thanks
Old Oct 11, 2011 | 01:28 PM
Terminator's Avatar
Here they say you can. Compatible with all ipods and iphones.
Old Oct 11, 2011 | 01:32 PM
Terminator's Avatar
Install is dead easy. VW radio removal forks provided with the unit work for our Becker radio. You pull out the radio. Cable supplied with the unit slots into CD charger socket. You drop the cable down the opening behind the radio. Plug into unit insert usb or cradle your ipod and that’s it. Mind you there will be no song names on the Becker radio just tracks. Make sure you order model 5 which says BECKER on the box.
Old Oct 12, 2011 | 10:19 AM
scottrx7tt's Avatar
I got an email stating that the Ipod adapters are currently on backorder, and it will be a few weeks before they get any more in.
Old Oct 12, 2011 | 11:33 AM
Skullbussa's Avatar
Skullbussa is infamous around these parts
Do you put your iPod in the cupholder? Where do you have the cable routing out from behind the stereo?
Old Oct 12, 2011 | 12:41 PM
Terminator's Avatar
Once radio is out stick your hand in and you will find there is a opening that leads right down to backside of the footwell. Check my photo.
Old Oct 29, 2011 | 08:58 AM
george_b's Avatar
george_b is infamous around these parts
Pcm1
Hi,
Will it work with my 2001 996tt with Porsche PCM1 navigation unit ?
And are you limited to 5 or 6 playlists with 99 songs each ? Still a lot of music i know, but was wondering.
Also want to add the blue tooth adapter for my I-Phone 4.
Thanks,
George
Old Oct 29, 2011 | 09:55 AM
Terminator's Avatar
I would have thought yes. Better check.
6 play lists. Per sd card or USB key of course.
Yes just add blue tooth module as accessory.
Old Oct 30, 2011 | 09:11 AM
george_b's Avatar
Sent Them an E-Mail yesterday, But looks like the way to go to me.
Thanks for the heads up
George
Old Oct 31, 2011 | 10:33 AM
Simi_996's Avatar
Simi_996 is infamous around these partsSimi_996 is infamous around these parts
George, keep us posted if this unit works with PCM1. I was under the impression that PCM1 and Becker radios were not similar.
