How to service a Turbo Charger?
Old Oct 25, 2011 | 02:23 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
blouch is the premier turbo builder in the USA
Originally Posted by salerno713
Fellas- I emailed TialSport and no answer back yet. Can anyone suggest a reputable company to do this procedure? They are Alpha3071s
Old Oct 25, 2011 | 02:25 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
True enough pump tech, I would do the same. Seems simple enough. But even different hybrid sellers use different wheels. Example, some clip the fins some use 6 some use 7 fins, they all seem to work, it seems like a preference/availability issue.
Billets are available here's an eBay link
http://motors.shop.ebay.com/snail-tu...1&_from=&_ipg=
Not sure if these are even available for our cars but I did this search in two seconds to see if any billet compressor wheels are available, voila of course they are, but quality, who knows.
If you look at more affordable tuning car forums you will find guys who have done this themselves, granted if something happens to there cars it's much cheaper to fix, but that being said alot of these guys are young with very limited incomes so it probably balances out.
Somebody must know the definitive answer, with risk vs reward. How sensitive is this work really? Brain surgery or ditch digging or something in between.
Old Oct 25, 2011 | 02:30 PM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
Thanks Pumptech-
Good point made Gearhead.
Old Oct 25, 2011 | 05:54 PM
pumptech's Avatar
Yeh but you still need a tune and I'm sure a 6 fin vs 7 fin versus whatever changes the volume of air moved and one versus the other you may not get the right tune. I guess logic says find someone with turbos you looking for and have them count the fins! At least that narrows it down some! I'm really leaning to 20G lately
Old Oct 25, 2011 | 06:18 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
You can get upgraded wheels, plenty of choices online. Plus there cheap. He did take the turbo from a 16 to 20 wheel without balancing it. Makes me wonder.
You could easily buy a different compressor wheel and fit that to your turbo
You will however have a problem with reinstalling the compressor housing - It won't fit as the new wheel is a different size
As a thought, you could strip a turbo, rebuild with new seals and gaskets and a larger compressor wheel, THEN take it to a shop for the machining and balancing
Remember, the guy in the video didn't need the housing machined as he bought one already done
I'd be interested to know what he did about the balancing though
The individual parts themselves do not require balancing, it's the rotating mass as a whole that gets balanced - It's like your Alloy wheels and tyres, you only balance them once they're fitted together
Originally Posted by pumptech
Well....I see 18 and 20g wheels on the web but scared to pick one up as i hear there are some with differences between one 18 to another such as number of fins and so on and so on. I even had a guy tell me the 18g and 20g wheel is actually a garret wheel even tho described as Mitsubishi. There certainly no billet wheels available!!!! If I knew exactly which wheel to get with part number I think I would take it on myself and send off for balance and machine housing.
I've spoken to someone who was looking into this too
The reason they didn't go through with it was that the turbine wheel sometimes gets worked on too (during the hybrid work) and as the work that's done (lightening and reshaping) seems to be a closely guarded secret they decided not to go through with it
I still think about it though, I might give it a go just for fun
Old Oct 25, 2011 | 06:36 PM
ant_8u's Avatar
Originally Posted by landjet
This looks like an hour long job or less for an experienced technician. Why did it take my former tuner 90 days to do this? Every time I called him during that time he was "working" on them. What a lying ****** bag he was.
I'll post a couple more videos for you in a minute
It's the machining rather than the stripping and rebuilding that takes time
BUT - the machining isn't some voodoo that's programmed into the machine, it's still done by hand, so it's definitely doable by someone that's got the skills and inclination
I have no skills, just inclination
Old Oct 25, 2011 | 06:39 PM
gearhead's Avatar
What about 16 to 16g? Does it require a new housing as well? I always wondered. This is what I have been thinking about lately or k16 billets plus of course all necessary tunes, fueling etc.
IF its just as simple as swapping wheels and 1 bar wastegates on good cores, that would be awesome but I am sure it's not, at least I hope it isn't with what they charge to do this service.
Not sure yet if billet is worth the price difference.
Maybe.
Old Oct 25, 2011 | 07:23 PM
pumptech's Avatar
Perhaps the guy doing the videos did ultimately do the balance but was showing rebuild just for demonstration purposes. Or perhaps he didn't change the alignment. Iv also heard that if the wheel is in perfect condition and has been previously balanced either factory or other it doesn't need to be rebalanced if pulled apart but even minuscule changes to the wheel can effect balance. I do know someone who has billet 18g wheels but wants $300 each. So $600 + $200 rebuild kits+ $130 balancing+ machining+ shipping you don't come out ahead!! But....when u do any of the "G" upgrades those prices don't get you rebuilds, just the wheel,spin, and housing machine. I would expect if anyone rebuilds their own turbos the best way to go is with the full rotating mass balance no matter what as you want that done right and don't want that in question if something goes wrong. Like I said this is about $65/ turbo and rebuild kits are $100ish, and when you send your stuff for balancing send the housing off for machine to same place, I don't expect it cost much either. But I don't think it's something you would try with a dremel!!! I'm sure we Can figure this out if we put a couple heads together.
Old Oct 25, 2011 | 07:28 PM
Tim941NYC's Avatar
http://motors.shop.ebay.com/snail-turbo/m.html?_nkw=&_armrs=1&_from=&_ipg=
Even if the wheel comes apart it will have a tough time getting through the intercooler.
Old Oct 25, 2011 | 07:30 PM
pumptech's Avatar
Don't know about the housing on the 16g or billets. I think the billets are well worth it as they are almost on par with the 18G. But havnt seen much info or 18G billets. I just don't think I would throw a new wheel on without a balance even if God himself said it was cool! Iv heard people say you can do it but no thanks!
Maybe.
Old Oct 25, 2011 | 07:39 PM
ant_8u's Avatar
Old Oct 25, 2011 | 07:56 PM
pumptech's Avatar
If I knew measurements of inducer and exducer diameter and fin number, that would really narrow it down
Old Oct 25, 2011 | 07:57 PM
gearhead's Avatar
You first, . I'm right behind you
Old Oct 25, 2011 | 08:05 PM
gearhead's Avatar
The 18g wheels say there already balanced, but I agree that the nut you put on the end wouldnt be, unless you scribe the shaft and nut. Hummm.
Old Oct 25, 2011 | 08:15 PM
pumptech's Avatar
Not today sir!! Best i can tell for the 20g it's the exhaust wheel that gets upgraded but the 18g it's the compressor cold side. I just got on this 20g kick in last week or so, so pardon my ignorance!
