How to service a Turbo Charger?
Old Oct 24, 2011 | 02:39 PM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
Figured id post this question in the 996 section. Does any one know if it is beneficial to service a turbo? I have a pair of Alpha3071s that were slightly used. I would like to have them serviced but dont know which direction to even start! Thanks in advanced.
Old Oct 24, 2011 | 03:28 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
What you planning on doing, and for what reason?
Old Oct 24, 2011 | 05:59 PM
salerno713's Avatar
I would like to put used turbos on my car that I got from a fellow 6speeder, but want to service, oil/lube any internal parts of the turbo that can be addressed or cleaned. Any ideas?
Old Oct 24, 2011 | 06:29 PM
ant_8u's Avatar
Servicing them is "usually" pretty straight forward, if that's all that you're planning on doing to them
http://www.youtube.com/watch?v=PSZtP...DC669D&index=1
http://www.youtube.com/watch?v=wqXe0...eature=related
I wouldn't advise anyone to try machining, balancing, or rebuilding a turbo though
Old Oct 24, 2011 | 07:57 PM
Tim941NYC's Avatar
You can send them to Anyone who works on Garrett turbo's. If the turbo's were used removed and are now sitting with you I would send them for a rebuild. Garrett had/ has and exchange program as long as the water lines were used. I do not run the water lines as the cooling system is taxed enough.
Old Oct 24, 2011 | 08:25 PM
HIX's Avatar
HIX
HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !
Yeah, it's certainly not something you want to do yourself. It's a pretty precise process. If I remember correctly Turbomasters is a pretty good outfit.
Old Oct 24, 2011 | 08:28 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
Why not send them back to Tial for service? That's what I would do.
Old Oct 24, 2011 | 11:01 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
You watch the videos and it makes it look like anybody could rebuild/hybrid a turbo. What about high speed balancing? Is it really necessary? The video would make you think differently.
Has anybody attempted this? And if so what were the results?
Old Oct 25, 2011 | 02:07 AM
x X CLoud X x's Avatar
x X CLoud X x is a glorious beacon of lightx X CLoud X x is a glorious beacon of lightx X CLoud X x is a glorious beacon of lightx X CLoud X x is a glorious beacon of lightx X CLoud X x is a glorious beacon of light
their are tons of companies out there that can service turbos pick your poison and send it in for a rebuild
Old Oct 25, 2011 | 06:42 AM
ant_8u's Avatar
If it's just replacing seals and bearings it's easy
If you're replacing other parts it's definitely a job for the pros!
Old Oct 25, 2011 | 08:02 AM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
Not first hand knowledge but allegedly just doing the seals and bearings is very straight forward. Don't need the balance job if u keep the original allignment but if you drop the compressor wheel your in trouble. Balancing is only 60-80 dollars anyway. Rebuild kits are about $100. U could rebuild urself and send off for balance just for fun. Too bad nobody will sell upgraded wheels or I expect some would be building turbos.
Old Oct 25, 2011 | 09:05 AM
landjet's Avatar
This looks like an hour long job or less for an experienced technician. Why did it take my former tuner 90 days to do this? Every time I called him during that time he was "working" on them. What a lying ****** bag he was.
Old Oct 25, 2011 | 01:05 PM
gearhead's Avatar
You can get upgraded wheels, plenty of choices online. Plus there cheap. He did take the turbo from a 16 to 20 wheel without balancing it. Makes me wonder.
Old Oct 25, 2011 | 01:25 PM
pumptech's Avatar
Well....I see 18 and 20g wheels on the web but scared to pick one up as i hear there are some with differences between one 18 to another such as number of fins and so on and so on. I even had a guy tell me the 18g and 20g wheel is actually a garret wheel even tho described as Mitsubishi. There certainly no billet wheels available!!!! If I knew exactly which wheel to get with part number I think I would take it on myself and send off for balance and machine housing.
Old Oct 25, 2011 | 02:17 PM
salerno713's Avatar
Fellas- I emailed TialSport and no answer back yet. Can anyone suggest a reputable company to do this procedure? They are Alpha3071s
