Pump Noise Behind Rear Seat
Old Nov 14, 2011 | 12:27 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
I have a noise that sounds like a small motor/pump running that comes from behind the rear seat area inside the car.
It happens when I shut the ignition off and hear a small motor start running for about 15 seconds. It happens sometimes with the engine running for about the same duration.
Any ideas?
TIA
Old Nov 14, 2011 | 11:19 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
You sure it's not your cooling fan in the engine deck lid? They turn on to continue cooling the engine sometimes after you turn it off or if it needs to while the engines running.
Sometimes the simplest things get missed.
Old Nov 14, 2011 | 11:33 PM
996TWINS's Avatar
It is not the cooling fan or from anything else in the engine compartment. I had my mechanic listen for it with the deck lid open with me in the car. He heard nothing, while I heard the noise came from behind the rear seat area.
A little baffled about this.
Old Nov 15, 2011 | 01:56 AM
gearhead's Avatar
Weird, there isn't anything back there that should make a pump sound?
Unless its aftermarket, even then not sure.
I've pulled all the carpet out, all thats back there is located directly behind the rear seats you can pull the carpet back to see its backed in foam and easily removable and replaced. Nothing under the carpet under the flat deck section.
Hope you figure it out.
Old Nov 15, 2011 | 10:11 AM
996TWINS's Avatar
I will pull the carpet and foam in the back, and have one of my kids help me figure out where the noise is coming from.
Old Nov 15, 2011 | 10:07 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Might be the secondary air pump. Just had mine worked on- has a high pitch wine at startup located in engine bay behind back passenger seat.
Old Nov 17, 2011 | 10:13 AM
996TWINS's Avatar
Will have my indy check this out. Thank you for the tip.
Another thing I discovered is that when I sit in the drivers seat with the ignition off, the noise starts and when get off the seat it stops, sit down again it starts again.
cnebrask
Oct 3, 2024 08:19 PM
r_matt_6
Oct 8, 2015 06:07 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
Zero911
Aug 24, 2015 06:51 PM
saline
Aug 19, 2015 12:25 PM
